Group Buys Members group buys
Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
Thread Tools
Old 27th November 2020, 08:40 PM   #211
Cardone is offline Cardone
I'm looking forward to my Vitaly amplifier -> -> -> made by russia .....
Old 1st December 2020, 09:52 AM   #212
drMordor is offline drMordor  Russian Federation
drMordor's Avatar
More parts have arrived)))
Everything except boards and TPA3255
Sorry, my english bad))) But I'm learning!
Old 1st December 2020, 10:30 AM   #213
It's great that you have received the goods
Old 1st December 2020, 01:41 PM   #214
nerone is offline nerone  Italy
Hopefully the pcbs and 3255 will arrive soon.
For Christmas it would be a nice gift under the tree
Old 1st December 2020, 10:26 PM   #215
turion64 is offline turion64  United States
Default Here’s my AllInOne amp build
I decided to mount it slightly differently...on its side directly over one of the casing’s floor vents. This way a natural convection flow would bring heat from the heatsink out the vent in the top of the case. A JLE speaker protection circuit is driven by its own 15V transformer while drMorder’s board’s extra 15V (+ & GND) output is sent to a simple LM7812 circuit to drive a silent 80mm 12V fan placed directly in front of the amp’s on board transformer. Sounds fantastic. You all will be very happy once you get yours.
Cheers, Pete
Consistency is the last refuge of the unimaginative - Oscar Wilde
Old 2nd December 2020, 08:53 AM   #216
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
turion64 / drmodor, I'm curious how good is the thermal connection between the chip and a heat sink and how it is ensured? The chip height is exactly that of the standoffs? some thermal paste in between?
Old 2nd December 2020, 09:01 AM   #217
drMordor's Avatar
Aluminum plate
Old 2nd December 2020, 12:08 PM   #218
tmuikku: as Vitaliy has just stated his PCB is mounted on a thick aluminum plate and it is secured to the PCB in several places what look to be key areas (either side of the 3255 as an example) to assure proper heat transfer. When I ran the amp w/o being in the case the plate got quite warm indicating (to me at least) that it was doing its job. I mounted his amp to another aluminum plate so the sideways mounted scheme could be achieved. I could see some sort of paste where the chip meets his heatsink plate but could not tell if there was an extra connection metal plating in between the 3255 and the heatsink plate nor did I want to take everything apart to check. The extra fan I added is probably unnecessary.
I’ve run the thing for hours, continuously, w/o any issues, but I don’t listen to my music at extremely loud levels so I can’t claim to test the amps limits. The good Dr can give further clarifications.
Cheers, Pete
Old 2nd December 2020, 12:14 PM   #219
Ah, the PCB sized aluminium plate I see in the pictures is already attached at assembly by drMordor and included in the purchase? Great!
Old 2nd December 2020, 12:21 PM   #220
Yes, here’s a picture of his amp (as I received it) while I was bench testing it; I use that term loosely since I’m not a probe & scope kinda guy.
Pete
File Type: jpeg 13969A30-29FA-415F-95EF-48DDC095E803.jpeg (641.4 KB, 179 views)
Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.Hide this!Advertise here!
Thread Tools
Compact TPA3255 design with PFFB and single PS zdr Class D 117 18th January 2021 06:47 AM
My 1st Class-D Amp -TPA3255 with PFFB JohnnyInBris Class D 26 17th August 2020 12:08 AM
TPA325x vs Full Digital Amp (FX502SPro vs D802C) forestsgump Class D 3 31st January 2018 07:39 AM
My new TPA325x DSP/Bluetooth/X Amplifier made for mobile Application mantabernd Class D 78 24th January 2018 03:12 PM
Akita 12V preamp thoughts prezden Tubes / Valves 13 23rd August 2013 03:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
