Group Buys Members group buys
ACP+ Preamp/HPA for Yarra Preamp
Thread Tools
Old 21st November 2020, 04:01 PM   #61
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
Thanks, I have some of those, so I’m good. Just wondered if you had an obscure source for the Fisher stuff.
M2x monoblocks - Daedalus Audio Muse Studio
(Analog) Technics SL-1200G/K&K Audio Maxxed Phono (Digital) Bricasti M12
Old 21st November 2020, 08:55 PM   #62
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Regarding the Fischer heatsinks: Just need to know someone in Germany.
The ACP+ as designed is really for driving headphones. So the bias current is a rather high 150mA. It runs too hot with these tiny heatsinks.
dBel84 did the following changes to drop the current and it runs at 40C.
R111 = 3K
R115 = 3R2
R117 = 10R
I seem to recall these settings were for about 70mA bias current. Plenty as a preamp and even for higher impedance headphones.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 22nd November 2020, 12:01 AM   #63
Techie Wanabe
Bones13's Avatar
Any way you could offer the lower bias option before the SMT work gets done?
And what would you recommend to do the same for the Hakuin board?
Old 22nd November 2020, 02:53 AM   #64
Got Foam?
xrk971's Avatar
We were already thinking of lowering the bias for the SMT prepop’d boards. The Hakuin is already set at a lower bias and heat is not an issue.
Old 22nd November 2020, 02:55 AM   #65
Techie Wanabe
Bones13's Avatar
TYVM!
Old 22nd November 2020, 01:07 PM   #66
Got Foam?
xrk971's Avatar
GB update:
MShipmanPE / SMT Prepopulated / 2 boards/ USA *Pre-Order Placed*
Carl_Huff / bare PCB / 2 boards / USA
mnichols30030 / bare PCB / 2 boards/ USA
Thompsontechs / bare PCB / 2 boards / USA God Bless it in these trying times!
Aljordan / SMT Prepopulated / 2 boards / USA *Pre-order Placed*
Pwagner / SMT Prepopulated (if enough interest) / 2 boards / USA
jwjarch / bare PCB / 2 boards / USA * Order Placed*
meanie / SMT Prepopulated / 2 boards / SGP
diy40 / SMT Prepopulated / 2 boards / USA
Itsmee / SMT Prepopulated / 2 boards / UK *Pre-order Placed*
Bones13 / SMT Prepopulated / 2 boards / USA *Pre-order Placed*
Afoor / bare PCB / 2 boards / USA *order placed*
Thank you Mshipman!
Old 27th November 2020, 01:01 AM   #67
Got Foam?
xrk971's Avatar
GB status update:
Pwagner / SMT Prepopulated (if enough interest) / 2 boards / USA *Pre-Order Placed*
Old 27th November 2020, 08:29 PM   #68
Got Foam?
xrk971's Avatar
Hi Folks,
We are going to test out the lower bias current configuration before committing to get the BOM for all the prepopulated SMT boards. So this will take another week or so then we will be in production. I have the PCBs and solder stencil already. Just need to order the MELF resistors and the opto and BJT. We are moving forward with this. Please place your pre-order soon if you are interested in the prepop'd board as the window is closing soon.
Thanks,
X
Old 5th December 2020, 03:56 AM   #69
Got Foam?
xrk971's Avatar
Hi Folks,
We have just tested the ACP+ with the new reduced bias current settings. The current is now 75mA vs 125mA and temps are down to 56C at the heatsinks. Even at 75mA you can drive moderate impedance headphones quite nicely. As a preamp though, it can drive any input of an amp. We are noticing that it will take some fiddling with various values of trim resistors to set the bias current of the JFETs precisely. There are extra large pads there so you can add in parallel, values that can fine tune the bias.
Old 5th December 2020, 01:35 PM   #70
Techie Wanabe
Bones13's Avatar
Thanks for the update!
I know everyone else here knows how, but, could you outline the bias setting? Where to measure, and the desired value. Is it twitchy enough that I should dial in with a trimmer resistor, and order a specific resistor value for each board? Or would a few smaller values (5R, 10R, etc) handle the range to add?
Ok, looked at the page on FirstWatt.com - 10 milliamperes across the R104/R105 parallel resistors.
If perfection is wanted, I would think leaving off the 200R, preset the trimmer pot to 200R, the adjust for desired bias, measure pot, and then order as close a resistor as possible.
Or is that too much work for obtaining a good result?
ACP+ Preamp/HPA for Yarra PreampHide this!Advertise here!
Thread Tools
Modifying a 12ax7 HiFi valve preamp to be a guitar preamp hoho Instruments and Amps 109 20th January 2021 08:21 AM
Viking RP61 tube preamp into Mic preamp? Magnetmaz Instruments and Amps 1 7th April 2015 09:47 PM
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 11:12 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 10:57 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
