Group Buys Members group buys
Ideal Bridge second GB
Old Yesterday, 09:41 AM   #61
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
If you consider that the first C in a typical tube PS is often in the region of 47uF and there are wide ranging debates about the exact type of this part you will appreciate that narrowing this choice to a ceramic is very limiting.
After all the sync rectifier replacement is aimed at the cognoscenti, right? Those who don't care about capacitors are happy using cheap diodes.
Old Yesterday, 09:48 AM   #62
analog_sa's Avatar
This can be made to look quite cool, even down to a valve socket, as a direct replacement for GZ34/83/etc. A voltage doubler can raise the PS for the 1170 out of the heater voltage and series connected 1170s can probably take care of the voltage requirements, so again 4 ICs for a centre tapped full wave rectifier. No local cap at all and no choke input operation, but this is a small price to pay.
Old Yesterday, 09:57 AM   #63
tvicol is offline tvicol  Europe
tvicol's Avatar
Ideal Bridge second GB Ideal Bridge second GB
This is a cool idea, that I should consider.
Tibi
https://evotronix.eu
Ideal Bridge second GBHide this!Advertise here!
Ideal bridge rectifier GB tvicol Group Buys 416 4th June 2020 05:38 PM
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
