Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Group Buys Members group buys |
Thread Tools |
#611 |
Got Foam?
Hi Wtnh,
So have you had enough time to listen to the new FH9 amp to tell us your listening impressions? I think you have LX mini's for speakers?
XRKaudio https://www.etsy.com/shop/XRKAudio |
#612 |
Only a few hours so far with my "street speakers", but I can say it is very clean in the midrange and high end and has plenty of low-end "grunt". I would describe it as effortless since it has so much reserve power.
I am still tweaking bias. My workbench area is a bit chilly (65 F) so it takes about an hour of playing at moderate volumes to reach thermal equilibrium. Still to do - button it up and do some full-power dummy load testing and distortion measurements. I may get brave and try it with my Martin Logans - but I will probably wait until I can install SSRs. I may a-b it with my McCormack DNA (500 Watts), but I suspect it will hold its own. So far I am very happy with the sound! I would recommend this amp to anyone wanting to build a quality A/B amp and I am very glad I chose it. |
#613 | |
Got Foam?
Glad to hear that the amp is sounding promising. Effortless is a good word to summarize it.
#614 |
Mine has been left on for weeks at a time. Still perfect and no bad behavior.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. | Buckeye | Solid State | 93 | 24th September 2020 03:51 PM |
December 2019, best sounding class D amp at the moment - Class of 100W @ 8 Ohm | Michelag | Class D | 11 | 5th December 2019 04:05 PM |
Make a class AB tube amplifier lean more towards "A" | jjasniew | Tubes / Valves | 24 | 5th August 2019 02:32 PM |
TDA7498 100W+100W Class D Amplifier | comasus | Class D | 1 | 18th November 2015 10:05 PM |
Audiom | 100-W audio amp is 20 times more efficient than Class D chips | coloradosound | Class D | 81 | 22nd June 2011 08:03 PM |
New To Site? | Need Help? |
