Group Buys Members group buys
Alpha Nirvana 39W SE Class A Amplifier GB
Alpha Nirvana 39W SE Class A Amplifier GB Please consider donating to help us continue to serve you.
Old 16th January 2020, 04:49 AM   #81
andyr is offline andyr  Australia
Originally Posted by xrk971 View Post
This is the Group Buy and Build thread for the Alpha Nirvana 39W SE Class A amplifier designed by AKSA.
PCBs:
Amp module looks like this assembled:
Hi X,
Comparing the 'built' pic against the PCB pic ... am I right in thinking that only one of C102, 103, 104, 105 gets populated on the PCB?
In your case, the 10uF Wima was used?
Thanks,
Andy
Old 16th January 2020, 05:16 AM   #82
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Yes, C102,103,104,105 are all the same input coupling cap. Simply there to give you choices as to what cap package you can use. Yes, I have a 10uF Wima MKP there. A 10uF Silmic II at C105 can work very well and hardly costs anything.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 16th January 2020, 05:57 AM   #83
Great - thanks, X.
Andy
Old 16th January 2020, 01:02 PM   #84
SanjeevM is offline SanjeevM
X,
Please consider adding a speaker protection circuit and relay on the amp board itself, it greatly simplifies wiring.
RPi 3B+/ Katana DAC THD / Allo Shanti / TPA3255 / MW LRS-350-48 / Paradigm Monitor 11 / Non-Electronics background
Old 16th January 2020, 02:09 PM   #85
Got Foam?
xrk971's Avatar
Hi Sanjeev,
If you like simplicity, please consider the ABBB amp. Very similar to the Alpha Nirvana, but 50w capable and has built in SLB and SSR DC protection and delay circuit. You just need to connect a trafo and speakers. It also has output MOSFETs and Cap Mx BJTs on quick connect Molex for remote mounting.
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB
Here is one channel of Vunce’s build:
Alpha Nirvana 39W SE Class A Amplifier GBHide this!Advertise here!
Alpha Nirvana 39w 8ohm Class A Amp xrk971 Solid State 675 Today 03:05 PM
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB xrk971 Group Buys 321 26th January 2020 01:18 PM
Aksa Lender P-mos Hybrid Aleph (ALPHA) Class A Amp GB xrk971 Group Buys 243 29th December 2019 08:23 PM
nirvana amplifier 400kg Solid State 11 31st December 2013 09:59 PM
Audio Nirvana Super 8 and 6B4G Amplifier AlejandroR Multi-Way 13 10th August 2006 06:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
