Group Buys Members group buys
NAP250 amp boards & regulator boards
NAP250 amp boards & regulator boards Please consider donating to help us continue to serve you.
Old 11th December 2019, 12:48 PM   #91
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Hi Klaus,
My research also led to the FR103 for clamp diodes, although they're obsolete and I couldn't find a source for them. I did come across several pictures of toasted FR103s, so the 1N5621 seemed like a reasonable substitute.
I'm less clear on the Baxandall. Naim did appear to use the 1N4148. While my sims show it having to dissipate 200mW running full whack into a 3ohm load (cf: Linn Isobariks), I've never seen one toasted, so I don't think that would have been enough to cause me to deviate from the original spec. So why did I?
Oh to still have the memory of a younger man....
Jeff.
Old 11th December 2019, 04:03 PM   #92
JeffYoung's Avatar
I did some more research on the Baxandall. While I didn't find much, I did find a recommendation from @Elvee that speed matters.
So originality favours the 1N4148.
But if you'd like the possibility of a bit more performance and a bit more survivability, the MUR120 looks to be a good candidate.
Jeff.
Old 11th December 2019, 04:27 PM   #93
lohk is offline lohk  Europe
lohk's Avatar
One more funny detail about the NAP250 - it may have been discussed before, but probably a long time ago:
The input socket of the Classic 250 is a single normal three pin XLR socket, wired L, R, Ground. The cable is, or at least was when I opened one more than 30 years ago, a bog standard mains cable, 1.5mm2, blue, black and yellow/green, unscreened.
Conclusio: Consequently low impedances make expensive cables unnecessary.
I still believe that, although with many components it does not seem to be that easy.
/lohk/
Old 11th December 2019, 04:37 PM   #94
lohk's Avatar
_
/lohk/
Old 12th December 2019, 04:03 PM   #95
lohk's Avatar
The NAP200 - still quasi complimentary, also due to the clearly visible bax diode - uses a 12 Ohm resistor for the Zobel part (probably with the usual 100nF). Also the bias tracking transistor sits underneath the board (maybe touching the case).
/lohk/
Old 12th December 2019, 04:15 PM   #96
lohk's Avatar
And it is the same for the NAP300
/lohk/
Old 12th December 2019, 10:48 PM   #97
John Luckins is offline John Luckins  Europe
Boards arrived here. Look great. Thanks Jeff.
Old Yesterday, 04:03 AM   #98
skunark is offline skunark  United States
Boards arrived, thanks again!
Jim
NAP250 amp boards & regulator boardsHide this!Advertise here!
FS: CSX1 Boards, Semisouth R125's, Firstwatt F6 boards, Dx Blame MKIII boards. ravid Swap Meet 4 20th January 2016 05:54 AM
FS: ALW Super Regulator Boards Ruach Swap Meet 8 1st August 2013 09:15 AM
alw regulator circuit boards fmak Solid State 1 3rd December 2008 05:11 PM
FS: TO-220 regulator boards BWRX Swap Meet 41 6th April 2006 04:03 PM
FS: DC regulator boards for 2A3 (or other) filaments Saurav Swap Meet 0 11th October 2003 09:33 PM
Copyright ©1999-2019 diyAudio
