Group Buys Members group buys
Group Buy for Jan's high voltage regulator
Old 17th September 2020, 12:00 AM   #251
Deke609 is offline Deke609  Canada
Deke609's Avatar
No luck with the tests. All of the following failed: (1) parafeed load (amp as designed) with 50K resistor across T-reg output; (2) same as (1) but with addition of 110 uF cap in parallel with 50K resistor; (3) same as (2) but with output transformers disconnected. In all cases, the T-reg output was unstable - randomly bouncing around +/- 1V rms or so.
I will look into the motorboating issue. I think I will need to scope the amp to explore this. Without the reg, with the output stage fed directly from the CLCLC filter, I don't hear any motorboating, or hum/noise of any kind. But I suppose there could be inaudible oscillation. I need to read up more about this and do some scoping. This will have to wait a week or more -- but I will report back on what I find.
cheers and thanks, Derek
  Reply to this post
Group Buy for Jan's high voltage regulatorHide this!Advertise here!
Maida-Style High Voltage Regulator PCB Group Buy SpreadSpectrum Group Buys 2 9th July 2015 01:25 AM
T-reg-high voltage regulator misterno Elektor 2 15th March 2015 05:25 PM
High Voltage Regulator mod_evil Power Supplies 36 28th October 2011 12:48 PM
high voltage regulator wleediy Solid State 2 4th August 2009 07:12 AM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
