Hi Nicmac, in this post it shows how to connect the grounds to an angled connector that then connects into a female connector on the relay board: Post 386
https://www.diyaudio.com/forums/showthread.php?p=5853048
Is this what you are looking for?
Example Arduino sketch to control VolCB board
I put together the attached Arduino sketch. It controls Hans Polak's 64-step VolCB and 4InputSelect boards. For simplicity, it uses two rotary encoders, one to select input, the other - volume. Use it as a starting point.
Awesome!
Thanks, Alex 👍
Thank you so much!!I put together the attached Arduino sketch. It controls Hans Polak's 64-step VolCB and 4InputSelect boards. For simplicity, it uses two rotary encoders, one to select input, the other - volume. Use it as a starting point.
Sorry to say this but I have none of the PCBs you are interested in. (I do have a few BPPBP and 16-step volume control board left.) I do not plan another run as there has been little additional interest. Thanks to Hans Polak's publishing the gerbers for his boards, you can order some PCBs for yourself though.
Hi Alex,
Are there any PCBs left. I’m interested in BPPBP AND 16 step Volume board.
Kemp
At this point, I only have a few 16-step volume boards left. Send me a PM if interested.
Thanks, I have ordered a Balanced Volume Control Board from your website. So don’t need preamp board for now. Still deciding about which volume board to go for...
Kemp
- Group Buys
- Interest in PCBs for Bruno Putzey's Preamp and Hans Polak's relay volume control
