Group Buys Members group buys
Interest in PCBs for Bruno Putzey's Preamp and Hans Polak's relay volume control
Old 13th February 2020, 02:32 AM   #91
Mike2 is offline Mike2  United States
Hey Alexy,
Thanks for replying. Ya, I understand how the encoder works. For some reason I was not expecting this. If you rotate the volume fast enough the pop is not too noticeable. But if go too slow it can be a little startling. I have it in my main system now for a listen. The other issue I have is it's too loud. I have it turned down to 1 and its still louder then I want. I may replace this with a regular pot until I have time to figure out a remote volume for this. Thanks again.
Old 13th February 2020, 03:00 AM   #92
alexcp is offline alexcp  United States
alexcp's Avatar
To reduce gain, you need to reduce R12/R22. From Hans Polak’s original article:
Gain can never be more than +6dB and never be less than -24 dB [...]. The fixed feedback resistor R12/R22 of 4K Ohm attached to the output amp determines the maximum gain of 6dB, but can easily be adapted to one’s need.
If you replace the resistors with, say, 2kOhm, the maximum gain will be 0dB, and the minimum gain will be -30dB. The easiest is to solder a couple of 4kOhm or so resistors (SMT 0805 or leaded) on top of R12 and R22 in parallel with them.
Old 13th February 2020, 03:28 AM   #93
I was just rereading Hans article and noticed this. I thought I remembered seeing something about adjusting the gain somewhere. I'll give this a try tomorrow.
Thanks again.
Old 14th February 2020, 10:48 PM   #94
Bennyboyph is offline Bennyboyph  United Kingdom
Would be keen to know if anyone has another solution to controlling the 64-stepper other than Maya
Old 15th February 2020, 04:02 AM   #95
shattered_dream is offline shattered_dream  Germany
Working on an arduino based solution... Think should t be a big Problem.... Just waiting for the parts...
Old 18th February 2020, 06:38 AM   #96
CentralCoast is offline CentralCoast  United States
Originally Posted by grayblob View Post
I have a full set of boards with the SMT soldering completed. If it is ok, I would like to offer it up at exactly the same price it was offered to me. $97 shipped via paypal. Please let me know if anyone would like them.
I'm interested in your boards. I also send a PM.
Old 18th February 2020, 07:58 PM   #97
Has anyone worked out a good enclosure and panel for the boards?
Old 18th February 2020, 09:01 PM   #98
How about a BOM for the 16 step volume control?
Old 19th February 2020, 03:06 AM   #99
alexcp's Avatar
BOM (and other documentation) is available here: link
Old 19th February 2020, 03:09 AM   #100
Interest in PCBs for Bruno Putzey's Preamp and Hans Polak's relay volume controlHide this!Advertise here!
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really) Bertel Analog Line Level 883 18th February 2020 08:19 PM
Wanted: Pearl2 or Non Plus Ultra Phono Preamp by Hans A. Polak Pella1 Swap Meet 6 5th June 2019 04:47 PM
FS: PCB for Non Plus Ultra Phono Preamp by Hans A. Polak Kim Bay Smidt Swap Meet 2 10th July 2018 05:15 PM
Bruno Putzey interview Zero D Solid State 5 30th May 2014 01:29 AM
Does anyone interest IN/OUT and STEP VOLUME CONTROL ? ANADIGIT Group Buys 3 26th February 2011 02:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
