Group Buys Members group buys
Simpelstark+ ODNF amplifier boards GB
Old 28th August 2019, 04:01 PM   #51
jwilhelm is offline jwilhelm  Canada
It depends a lot on the hardness of the wire too. Belden wire is usually pretty stiff and terrible to work with. It's already pre-kinked coming off the roll! CNC Tech wire from Digikey is nicely annealed and forms beautifully.
https://www.vzaudio.com/
Old 29th August 2019, 02:11 PM   #52
Mituisho is offline Mituisho  Hong Kong
tuyen - 1x (1) + jfets
pinnocchio - 1x (1) + jfets
yogiDIYbear - 1x (1) + jfets
manniraj - 1x (1) + jfets
outtek - 1x (3) + 2 x jfets
cl00sed – 2x (1) + 2 x jfets
PurpleTube – 1x (3)
Touchdown - 1x (1) + jfets
twocents – 1x (2) + jfets
Janku - 1x(1)
Arthur- 2x(3) + 2X jfets
markus22ch 1x(3) + jfets
Vunce - 1x (1) + jfets
mituisho 1x(3) + jfets
Old 29th August 2019, 02:25 PM   #53
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Jeff, Valery,
Is there any other transistors that require matching?
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 29th August 2019, 03:09 PM   #54
Outputs may be better from the same manufacturing batches but with 1R emitter resistors it wouldn't likely make any difference.
Old 29th August 2019, 06:44 PM   #55
TerraMonkey is offline TerraMonkey  United Kingdom
Default Count me in if I'm not too late please!
cl00sed 2x (1) + 2 x jfets
PurpleTube 1x (3)
twocents 1x (2) + jfets
Janku - 1x(1)
TerraMonkey 2x(3) + jfets
Old 30th August 2019, 05:09 PM   #56
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Sure, no problem
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 31st August 2019, 04:07 PM   #57
vzaichenko's Avatar
Arrow GB ordering is OPEN
OK buddies, I'm opening ordering for the GB a little bit in advance - right now!
Please make your order via the web store at:
Virtual Zero Audio Store
The reason I'm asking to do it that way - our shipping process is pretty much automated with the tools in the store, plus you will be able to specify the address and choose the preferred delivery method for your convenience.
Please put the desired products to the shopping cart, adjust the quantity if required, and proceed to checkout.
All the GB products are visible at the top of the front page.
Please specify the discount code at the checkout: DIYAUDIO
It will drop 25% off the price of the boards, resulting in the prices, announced earlier. It will not affect the price of jFETs though.
Please let me know if you will have some questions / need assistance with the process.
I will duplicate this message in post #1.
Valery
http://vzaudio.com/
Old 31st August 2019, 06:14 PM   #58
vzaichenko's Avatar
Hello All,
One of the list members just had an issue with shipping options - at the checkout.
After a quick troubleshooting, the problem was solved. I made a stupid mistake with the boards' bundle weight (340 kg instead of 340 g).
In case somebody else had this problem - please clean the cart, refresh the page, add the products to the cart again - it will work properly now.
Sorry for possible inconvenience.
Valery
http://vzaudio.com/
Old 31st August 2019, 07:57 PM   #59
manniraj is offline manniraj  India
I see that using the discount coupon DIYAUDIO we get the 25% discount on the PCB board sets. But as per this thread and one of the posts you said that you will be giving the JFETs for $5. Your site does not take into consideration about this JFETs lowered price but still takes it at $9.99. So not sure when you said $5 is for a pair and this amp boards require 2 pairs. Please clarify.
Old 31st August 2019, 08:10 PM   #60
vzaichenko's Avatar
Hi Manniraj,
Jeff has mentioned the price in Post #26 as $5 for a complementary pair.
One set for a stereo amp contains 2 x pairs at a total of $9.90.
We don't discount them as this is close to the cost we've got them at.
Valery
http://vzaudio.com/
Simpelstark+ ODNF amplifier boards GBHide this!Advertise here!
FS: CSX1 Boards, Semisouth R125's, Firstwatt F6 boards, Dx Blame MKIII boards. ravid Swap Meet 4 20th January 2016 05:54 AM
fs amplifier boards potepuh Swap Meet 2 21st December 2015 04:05 PM
ODNF or no GNFB power amp dadod Solid State 97 26th November 2013 10:19 AM
FS: UP amplifier boards Siberia Swap Meet 2 19th February 2013 05:17 PM
Copyright ©1999-2019 diyAudio
