Group Buys Members group buys
Simpelstark+ ODNF amplifier boards GB
Old 10th September 2019, 03:59 AM   #101
gaborbela is offline gaborbela  Canada
Hi Valery
Interested on a pair PCB, shipping to Toronto Canada.
Thank you
Greetings gabor
Old 10th September 2019, 04:05 AM   #102
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Hi Jeff,
What has changed from the original design?
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 10th September 2019, 07:45 AM   #103
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Originally Posted by gaborbela View Post
Hi Valery
Thank you
Greetings gabor
Hi Gabor,
Can you please place the order via our web-store, using the discount code DIYAUDIO. It will be shipped from New Hamburg as usual ))
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 10th September 2019, 09:34 AM   #104
jwilhelm is offline jwilhelm  Canada
Simpelstark had an odd size pattern for it's small caps so I changed it to .200" centers. The balanced adapter is new and Amp Control V6.22 has a new voltage loss detection circuit.
https://www.vzaudio.com/
Old 12th September 2019, 07:39 PM   #105
Default Board Update
I've managed to test most of the boards. Simpelstark and the supplies are good. There's a bug in the Amp Control boards, I'll have replacements early next week. I haven't managed to test the new input adapter board yet, I hope to do that in the morning. I should be able to start shipping out some of the orders tomorrow.
Old 14th September 2019, 07:42 PM   #106
vzaichenko's Avatar
Hello All,
I have slightly updated the build guide for Simpelstark+ in the store for making the ODNF setup more clear. The attached picture illustrates what kind of signals you are going to see at the output of the amplifier and at TP2 test point.
ODNF circuit is balanced as soon as the amplitude of the error signal at TP2 is at its minimum (trimmed by R26).
The signal generator can be very simple - Android application like this is enough (1KHz sine wave is enough for the above procedure):
Frequency Generator - Tone Generator - Apps on Google Play
Valery
http://vzaudio.com/
Old 16th September 2019, 07:23 AM   #107
TerraMonkey is offline TerraMonkey  United Kingdom
Cool Beans!
Old 18th September 2019, 06:29 PM   #108
pinnocchio's Avatar
Got my boards yesterday! Beauties!
Thanks Jeff and Valery for this GB!
Old 19th September 2019, 10:02 PM   #109
Amp Control 6V2.3 is up and running perfectly. It has an extra 12V switched connector on it that will work nicely to switch the new input adapter boards. I'm going to update the software so a rear panel switch can be connected to one of the pins on the ISP port, the control board will check the switch position on power up and set the input adapter to the correct input before powering up the amplifier.
Debugged input adapter boards should be arriving tomorrow so with any luck I should be able to package everything over the weekend and ship everything out.
Old 20th September 2019, 10:16 PM   #110
The new input adapter board is working perfectly. TD looks like a loop-back test on my distortion analyzer! I'll try to package everyone's orders this weekend and get them in the mail on Monday.
Simpelstark+ ODNF amplifier boards GBHide this!Advertise here!
FS: CSX1 Boards, Semisouth R125's, Firstwatt F6 boards, Dx Blame MKIII boards. ravid Swap Meet 4 20th January 2016 04:54 AM
fs amplifier boards potepuh Swap Meet 2 21st December 2015 03:05 PM
ODNF or no GNFB power amp dadod Solid State 97 26th November 2013 09:19 AM
FS: UP amplifier boards Siberia Swap Meet 2 19th February 2013 04:17 PM
Copyright ©1999-2019 diyAudio
