Great news, and thank youi get my board. It is a piece of art. When I can build that amplifier on that same level, it can only become great. Thanks.
Thanks for letting me know....its a good looking PCB isnt it!My board just arrived. It's so nice looking I'm almost sorry to solder on it. Now I just have to wait for transformer to arrive
Your Transformer was posted this morning
The load sockets are to use with MM or MC carts. If you need more Capacitance for your MM carts, you can add a capacitor there, or if you need 400ohm for you MC cart, you can add the requisite resistor there instead.@Bigman80
Hi mate.
I have a question regarding “LOAD” positions, left and right, on board - what is the function?
Could you explain me a little bit, please.
Kind regards.
S.
I usually install RCA socket and make loading plugs to insert with whatever value resistor I need, soldered to the RCA plug.
The load sockets are to use with MM or MC carts. If you need more Capacitance for your MM carts, you can add a capacitor there, or if you need 400ohm for you MC cart, you can add the requisite resistor.
Or you kan add a switch to make it variable .
AbsolutelyOr you kan add a switch to make it variable .
OK, RCA plug with resiestor or capacitor.
You add whatever values are required fornthe cartridges you have.Does anyone have any idea regarding the values of resistors and capacitors if make it variable with rotatory multi contact switch?
Do you have some “know how” example to help me?
Thank you in advance.
I have used 6 posision multi swich with 10-47-100-248-474-1000 ohms resistors.
Thats for my Denon 2 MC pickup.
And for MM-?
What about sch?
The person who designed this phonostage only agreed to a GB if the schematic was not published.
- Group Buys
- Bigbottle MM/MC Hybrid Valve Phonostage PCB
