Group Buys Members group buys
TPA3255 Reference Design Class D Amp GB
Old 25th August 2019, 09:49 PM   #81
manudrz is offline manudrz  France
Originally Posted by xrk971 View Post
We will provide a single-click to order shopping cart for the BOM from Mouser. Vacuphile has offered to assemble the shopping cart as a Beta tester. Kay Pirinha has also offered to be a Beta tester.
Nice! I think we all know it's not a cheap project (you have ebay for that), but that amp is intend to play for years so lets go on...
Old 26th August 2019, 12:52 AM   #82
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
More than just last for years - features are now available that are not to be found on the cheap Chinese amps, and the performance should be better with good components and careful layout. Parts cost probably $80 to $120 depending on quantity. We won’t know until Vacuphile makes the shopping cart on Mouser.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 26th August 2019, 02:10 AM   #83
blossom is offline blossom  New Zealand
blossom's Avatar
What about adjustable gain on the inputs for when used in multi way applications? To keep the noise floor low on things like compression drivers.... ????
Old 26th August 2019, 01:09 PM   #84
Got Foam?
xrk971's Avatar
You can adjust the input gain by varying the resistors on the analog input stage balanced pre section - although not sure how much range there is to do that without it affecting other aspects. It is unity gain at present. This amp has 22dB gain and if people want to drive it to clip with normal line level signals, an 8dB to 10dB preamp for volume control would be useful.
The PCBs are suposed to arrive today.
Old 26th August 2019, 10:03 PM   #85
Got Foam?
xrk971's Avatar
The PCBs are in - they look great! Thank you, JPS64!
TPA3255 Reference Design Class D Amp GB-tpa3255-pcb-photo-01-jpg
TPA3255 Reference Design Class D Amp GB-tpa3255-pcb-photo-02-jpg
TPA3255 Reference Design Class D Amp GB-tpa3255-pcb-photo-03-jpg
Old 27th August 2019, 07:58 AM   #86
blossom's Avatar
Looking good!
How many Hours would you say is in soldering one of these boards? For a beginner?
Old 27th August 2019, 11:08 AM   #87
Got Foam?
xrk971's Avatar
Assuming the beginner practices solder paste and hot air / hot plate soldering technique on test board first and can successfully solder 0603 parts and larger electrolytic SMT caps, maybe 4-6 hours. The self “training” on test boards is probably 2-3hrs.
You need a $40 hot air SMT rework tool. A $10 skillet, a $10 dorm room hot plate, $15 IR thermometer, $15 syringe of solder paste, $20 SMT tweezers, $10 magnifying flip up goggles, liquid flux $10, solder braid $3, and regular soldering iron. Those are the bare minimum tools and supplies needed to solder this yourself.
More tips here:
Making balanced output from single end
This is how I soldered this board:
Old 27th August 2019, 12:50 PM   #88
doctormord is offline doctormord  Germany
doctormord's Avatar
Hmm, soldering big inductors on 2mm 2oz. copper pcb might be a challenge with just using a hot air gun. You'd probably need to preheat the pcb as well. (Or solder them with an iron and leave out the mounting tab)
Btw. You have Conformité Européenne documents available, as indicated by "CE" on the PCB?
Old 27th August 2019, 02:18 PM   #89
Got Foam?
xrk971's Avatar
The large parts like inductors and electrolytics need a hot plate preheat from bottom and hot air from the top.
Old 27th August 2019, 03:42 PM   #90
Got Foam?
xrk971's Avatar
Dr Mord,
The CE label is just that, a label on the PCB. For the device to be CE certified for commercial sales, it has to go through CE testing of course.
Your 1200w DC-DC boost converter looks interesting are those sold as finished and tested units? How much does 1 cost?
TPA3255 Reference Design Class D Amp GBHide this!Advertise here!
TPA3255 - all about DIY, Discussion, Design etc. lms Class D 1372 Today 08:55 PM
My 1st Class-D Amp -TPA3255 with PFFB JohnnyInBris Class D 23 25th June 2019 05:18 PM
Class d TPA3255 Arjunkumarm Class D 2 16th March 2019 05:06 AM
Which Class D amp - Sure AA-AB32313 or TPA3255 tribute Class D 36 6th November 2018 07:37 PM
Reference Question regarding class D bl4ckw1d0w Class D 1 2nd October 2012 12:58 AM
Copyright ©1999-2019 diyAudio
