Group Buys Members group buys
Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
Old 1st April 2020, 04:26 AM   #541
andyr is offline andyr  Australia
Originally Posted by xrk971 View Post
Those other pins are optional test points and flying lead connection pads. Simply use your DMM in continuity mode to find out which is which.
Great - thanks, X.
Andy
Old 1st April 2020, 09:56 AM   #542
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by Mike Hanson View Post
If I'm providing a separate supply, then it has both positive and ground, and its ground is not the same as the amplifier's ground. Hence, my question about whether those two grounds (board supply ground and audio ground) are common on the board.
Could you just connect the GND of your separate PSU to the existing GND of your amp? Then the two GNDs would be the same and all is good.
But... taking this thought one step further: what if none of the speaker outputs are connected to GND, for example in a bridged amplifier? While the DC across the terminals might be fine, there may be a bit of DC from each terminal to the PSU GND. If the DC protection board senses the DC from the speaker output relative to the PSU GND, it will turn off the speakers, although there is no (significant) DC across the speaker terminals. Soooo... one could add a separate PSU for the DC protect board (for example a cheap SMPS or wall wart), and connect the "GND" of this separate PSU to one of the speaker output terminals? The DC protect board would then only sense the voltage across the speaker terminals, not the terminals relative to the GND of the main PSU.
Would that work? Would it work well? Any issues with this?
Scan waveguides (elliptical / circular) – MATAA audio analyser – Open Source Monkey Coffin
Old 1st April 2020, 12:05 PM   #543
Mike Hanson is offline Mike Hanson  Canada
Actually, the voltage regulator can handle 150v. However, make sure the voltage drop x 4mA dissipation isn’t too high. 60v - 15v is 45v x 4mA is 180mW. That should be fine. You can use the on board 60v supply.
That's perfect, thanks!
Old 4th April 2020, 08:35 PM   #544
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
This was actually the change proposed for version 2 of this circuit. The PSU to actuate the SSR could be from the amp itself or another PSU, and the ground of the actuation circuit would be isolated from the amp return. When the second batch sells out maybe we can go to version 2. This will handle BTL amps and will have a remote trigger for instant shutoff when the main PSU is switched off. But getting a new production with a new circuit and BOM is quite a challenge.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 5th April 2020, 06:11 PM   #545
mbrennwa's Avatar
Yes, I remember that discussion.
I am just wondering if my idea would work.
Old 5th April 2020, 06:53 PM   #546
jhofland is online now jhofland  United States
The current version of the SSR connects the aux supply - (GND) and the AMP low side, also GND. The offset is sensed between AMP high side and AMP low side (GND). Whether the SSR power supply is derived from the amplifier power or a separate supply does not change this. Using this version with bridge tied outputs works if, and only if, there is no offset from zero volts on the high side outputs with no input signal.
Old 8th April 2020, 03:49 PM   #547
mbrennwa's Avatar
Yes, sure, but... what if I have a floating helper PSU for the SSR, with the "low" end of the PSU connected to one of the speaker outputs? The SSR would not know that it is not referenced to the main amplifier GND. Instead, I guess the SSR would just sense the DC relative to the "low" end of the helper PSU. Right?
Old 8th April 2020, 04:23 PM   #548
That is right, kind of. If that floating supply is truly floating then there is no closed current loop between the amplifier output and the SSR circuit. The the sensing part of the circuit is an RC lowpass network connected to the IR LED in an optocoupler and then to the amplifier low side to form a closed sensing loop. That low side is connected to the - side of the circuit power.
Old 10th April 2020, 09:36 AM   #549
mbrennwa's Avatar
That is right, kind of. If that floating supply is truly floating...
What do you mean by this? How would a floating supply not be "floating"? For instance this: RS-15-24 MEAN WELL | Mouser Schweiz
Old 10th April 2020, 12:13 PM   #550
Shawnstium is offline Shawnstium  United States
The mean well is an isolated supply, meaning the output is isolated from the input (line/source) and thus the output voltage can be considered floated from other voltages produced from that source. Those outputs will not longer be floating if they are electrically connected to another DC source, thus the mean well’s output will somehow be referenced to the other DC source.
You can check (to certain level of confidence) if source is floating from another by measuring the voltage across the two supplies.
Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GBHide this!Advertise here!
speaker protection with delay angrypat Solid State 2 14th October 2018 01:33 AM
dc protection and delay circuit gev Parts 0 14th June 2013 08:32 PM
Speaker protection and delay from diy store BeaufortRalph Solid State 0 6th August 2012 02:48 PM
NAD C320 Amp Protection delay help please Kajman Solid State 2 15th December 2007 03:24 PM
6 channel Speaker Protection and power on delay sachi Chip Amps 6 18th November 2005 04:58 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
