xrk971 - 4 units - USA
pinnocchio - 6 units - CAN
Vunce - 4 units - USA
Miggie78 - 2 units - FINLAND
Nautibuoy - 2 units (maybe 4, depending on price) - UK
gary s - 4 units - AUSTRALIA
WTL- 4 units - AUSTRALIA
ppap64 - 2 units - CANADA
drpro - 4 units - USA
Alarudin - 2 units - SINGAPORE
Ripcord - 2 units - USA
Myint67. - 4 unit. -Singapore (depends on price )
av-trouvaille - 2 units - NL
ravid - 2 units -India
darrr - 2 units - Poland ( depends on price )
Avtech23 2 (maybe 4) units - Australia
bkdog - 4 units - Australia
necplusultra- 2 units Dominion of Canada
gannaji - 4 units USA
Amplitude - 2 units Denmark
esprit - 2 units - UK
hirscwi - 4 units - USA
yoaudio - 4 units - USA
kamco - 6 units - USA
Baobei - 2 units - UK (depends on price)
TOTAL = 78 boards.
TOTAL = 78 boards.
Kokanee - 4 units - Canada
TOTAL = 82 boards.
Report Post
TOTAL = 82 boards.
Report Post
Abanico-2 units- Spain
Rev 1.0 Updated Pre-Prod Schematic
Here are the latest 3d renders and schematic with voltage regulator IC for supply voltage control, 100v MOSFET, and protection transorb diode.
PCB only:
Your choice of connectors to speaker, Faston:
Molex Minfit Jr Horizontal:
Molex Minfit Jr Vertical:
Schematic:
PCB only:
Schematic:
I will let jhofland answer, but I think on bridged amp, both wires are "live", so you might need two of these and don't connect the ground pass-through connector to any of the speaker wires. Just connect the supply ground and power source and one speaker wire through the SRR switch side.
I make it clear from the outset that I often miss detail that's obvious to others.
How is the board placed in the overall circuit, in terms of where it sits in relation to incoming mains power, transformer, amp PCB and speakers?
The way I'm reading the base detail is that one board per channel is required.
Pardon my confusion because the diyAudio Store equivalent has the soft start between the mains and the transformer and the speaker protection between the amp PCB and each speaker. I'm just trying to relate this bit of gear to an architecture that I currently understand.
Thanks in advance.
Thanks in advance.
It goes after the amp’s speaker outputs and before the speaker terminals. It needs a connection to the amp’s +ve supply from the PSU. This provides it the power to work and do its thing. It does not have a soft start - that’s part of the power supply. What it has is a delay that doesn’t connect the speaker until after 3 seconds to allow the amp to release its start up transient with the speaker not yet connected.
vasilis-4 units-Greece
astromo-6 units-Australia
mlloyd1 - 2 units - USA
Make that 96 units
mlloyd1
Make that 96 units
mlloyd1
tony.garner-2units-UK (depends on price)
THANKS!
markus22ch - 6 units - Switzerland
- Group Buys
- Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
