Group Buys Members group buys
GB: Round #5; Fo-Felix AC Filter
Old 27th August 2019, 07:08 PM   #21
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Not directly. We model a fair bit because real world variables are so high we can't really account for measuring in one setting being accurate for multiple settings.
Also we listen. A lot of filters sound horrible IMO. They measure ok on a 50-50ohm setting but that isn't very real world. They also don't account for resonances very often.
Old 30th August 2019, 09:43 AM   #22
shattered_dream is offline shattered_dream  Germany
Hmmmm ok...
Different question.. Wuerth has common mode chokes too... Especially flat ones.... From the values would one of these be suitable?
Old 30th August 2019, 11:58 AM   #23
astromo is offline astromo  Australia
Originally Posted by shattered_dream View Post
Hmmmm ok...
Can you post a link?
If the key specs check out and PCB pin layout works, why not?
Old 30th August 2019, 05:45 PM   #24
Hmmmm ok...
A link would be good. From the description alone it sounds like differential mode for a car, which really only works at DC or in minor, minor amounts that have to be controlled carefully.
Old 31st August 2019, 09:03 PM   #26
All of those could work, used on the fuse. They don’t offer any differential filtering like the Comocos though. But the pin spacing if probably off (I’m on phone, hard to check).
The same wattage type values would apply just fine, too.
Old 31st August 2019, 10:20 PM   #27
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Destroyer, I bought a few of these from a local surplus supplier and use them in all my amps.
https://ch.schurter.com/en/datasheet/typ_FMLB-09.pdf
Is there any benefit in using your pcb or are they similar performance?
thanks.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 2nd September 2019, 07:13 PM   #28
The Fo-Felix with any given CMC is higher filtration. Also the M5 is the only one in that PDF without Y caps, that often are a determent to sound with single ended operations.
I suspect those are better than the IEC inlet filters that sound awful.
Old 5th September 2019, 08:12 AM   #29
Thanks Destroyer.
GB: Round #5; Fo-Felix AC FilterHide this!Advertise here!
GB: Round #4; Fo-Felix & GB #1 AC Receptacle Enclosure Destroyer OS Group Buys 53 28th June 2019 03:14 AM
GB: Round #3; Fo-Felix & GB #1 AC Receptacle Enclosure Destroyer OS Group Buys 111 31st March 2019 07:08 AM
GB: Fo-Felix EMI Filter for AC mains 120/230v; By Folsom Destroyer OS Group Buys 157 23rd March 2019 11:48 PM
GB: Round #2; Fo-Felix EMI Filter for AC mains 120/230v; By Folsom Destroyer OS Group Buys 192 9th March 2019 05:19 PM
Active filter GB - another round is planned quickshift Multi-Way 2 28th January 2008 02:28 PM
Copyright ©1999-2019 diyAudio
