Group Buys Members group buys
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB
Old 5th August 2019, 10:44 AM   #191
aive is offline aive  Australia
Originally Posted by Vunce View Post
Thanks X!
I’m running 37vdc after the onboard capMx and .600vdc across the parallel sensor resistors, I believe that’s approximately 2.75A bias current.
All cpu temperatures are very well under control. The Mosfet coolers are running 37°C at the fins and 50°C at the aluminum angle clamp bar.
The amp at idle is silent with my test speaker setup, but I will hold off judgement until I hookup to my main speakers that are very efficient and reveal any noise.
I was listening for about 2hrs tonight using an iPhone—>Bluetooth module with Toslink output into an “old school” R-2R Dac. For only a single channel now, the ABBB sounds wonderful !!
What’s the secondary rating of your transformer out of interest?
Old 5th August 2019, 10:56 AM   #192
Vunce is offline Vunce  United States
I’m using a 600va, 32v Antek transformer for each channel. You could use a 500va as well.
The 12v tap can be used for a small linear psu to power the fan controller.
AN-6432 - 600VA 32V Transformer - AnTek Products Corp
Old 5th August 2019, 11:10 PM   #193
Cool - I got 500 VA 32v trannies so should get similar results hopefully
Old 5th August 2019, 11:28 PM   #194
Should be no problem Aive,
I probably went a bit overkill with my transformers
Old 17th August 2019, 10:42 PM   #195
wmchugh is offline wmchugh  United States
Hi I realized I had forgotten to post on this thread out of my eager to place the order on Etsy. I placed my order on July 4 at 6:41pm. It was Order #1481075195 just to clarify. PM me if you need.
Old 18th August 2019, 12:00 AM   #196
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Good news folks. I just got word that the ABBB boards just completed manufacturing and are being packed for delivery to USA. Probably another 5 days before I receive the boards and will send out by next weekend. You will receive at no extra charge, a set of 4 mini boards per amp channel that will let you solder the BJT and MOSFETs to and then the flying leads can be either soldered from there or you can choose to use Molex connectors (premade PC power cables). The mini boards permit installation of a snubber right at the MOSFET pins - Something we found critical to prevent oscillations.
File Type: jpeg 26C3C0C4-5146-4437-844E-E82B45E46719.jpeg (405.5 KB, 123 views)
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th August 2019, 02:03 AM   #197
Originally Posted by xrk971 View Post
Good news folks. I just got word that the ABBB boards just completed manufacturing and are being packed for delivery to USA. Probably another 5 days before I receive the boards and will send out by next weekend....
Excellent news X!
Soon to be newborn ABBB’s out in the wild
Old 20th August 2019, 02:25 AM   #198
meanie is offline meanie  Singapore
Patiently waiting for mine to arrive.
Thanks, X!
Marantz 7 clone(25 years old) - BabyHuey EL34s - BA3FE - 2ACA - F6 - M2X - 2Whammy - USSA5.0 - USSPA (in progress) - Yarra Preamp(in progress)
Old 20th August 2019, 11:47 AM   #199
Got Foam?
xrk971's Avatar
Tracking info says DHL will deliver the ABBB package tomorrow.
Old Yesterday, 12:53 AM   #200
Got Foam?
xrk971's Avatar
I’m on travel - currently in Cleveland, but just got a text message from DHL saying that the ABBB’s have been delivered to my home in Virginia.
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GBHide this!Advertise here!
Aksa Lender P-mos Hybrid Aleph (ALPHA) Class A Amp GB xrk971 Group Buys 239 25th July 2019 07:36 PM
YBA 1 alpha nrg1951 Solid State 0 5th January 2018 05:49 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
Arcam Alpha plus v. Alpha 5 plus v. Rotel RCD 855 dynoPort Digital Source 1 30th March 2011 11:19 AM
Has anyone used the Alpha 15 in a two way? Godzilla Multi-Way 2 20th September 2010 09:39 PM
Copyright ©1999-2019 diyAudio
