Group Buys Members group buys
Folsom EC7293: PVI Powered Frontend, 60/120w 8/4ohm
Thread Tools
Old 8th October 2020, 08:03 AM   #301
mctavish is offline mctavish  Austria
So I got the boards assembled last night! Everything went well, some of the resistore had to be mounted vertically due to space issues.
The one thing that was a bit of a challenge was the transistors....
I have been soldering for 30 years or so and I still had to really concentrate and pull out all of my bag of tricks to get them all soldered on!
The one thing missing is the cap that comes after the solar cells... What value and voltage should that be?
Now I am just waiting on the Leds, Solar cells, and the power trafos. I am thinking about Toroidy as I have had good experiences with them in the past.
Thanks again Jeremy for the great design!!
Old 8th October 2020, 09:49 PM   #302
zek is offline zek
zek's Avatar
Why did you bend the legs of small transistors?
Old 9th October 2020, 06:29 AM   #303
Because there are no through holes on the PCB for the transistors, there are only flat pads. Plated through holes would have made it a lot easier, for some reason this design just has three flat soldering Pads....
Old 9th October 2020, 08:39 PM   #304
zek is offline zek
zek's Avatar
That's really weird.
If it’s a single-layer board, I’d drill holes in it for those little transistors.
Old 10th October 2020, 01:17 AM   #305
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Do NOT drill the board.
Old 10th October 2020, 01:22 AM   #306
680-1000uf 16vmin, same size as feedback will fit.
Glad you were able to solder transistors. This wasn’t intended for a beginner project. The way I do it is to carefully trim the leads first, pool a little solder on the back leg pad, and try to tin the back leg real quick. Then hold the transistor where you want it and heat the pad, the leg will sit down in the pool onto the pad. You can just just solder the other joints like anything else. It doesn’t feel out perfect but is repeatable.
Old 29th October 2020, 12:59 PM   #307
So I have found a killer deal on some toroidal trafos that are overstock. They are 300va but they have 30v secondaries.
Would 30v. secondaries be to far out of line for the voltages on the boards or would they still be usable?
Thanks guys!
Old 29th October 2020, 07:56 PM   #308
It would mean the capacitors that were in the BOM would be insufficient for handling the voltage on them. But yes you could run that high as long as you have adequate heatsinks.
Old 31st October 2020, 01:50 PM   #309
jameshillj is offline jameshillj  Australia
I'm slowly ploughing thru the threads about this amp, the basic power supply and the Fo-Felix line filter and kept on coming across the reference to this "Antipole Power Supply" and wondered what it was?
Then, on Audio Circle, it seems to be part of the design of the 7297 chip amp's supply - it appears to be a cap multiplier p/s filter but I don't see any mention of it - doesn't it work here?
Old 31st October 2020, 04:05 PM   #310
The Antipole is just a single rail PSU.
  Reply to this post
Folsom EC7293: PVI Powered Frontend, 60/120w 8/4ohmHide this!Advertise here!
Thread Tools
GB: Fo-Felix EMI Filter for AC mains 120/230v; By Folsom Destroyer OS Group Buys 207 17th November 2020 04:23 AM
Folsom LOFI PCB's (Transformer board) & DC PCB's (PSU boards) Destroyer OS Group Buys 58 20th October 2020 11:48 PM
Folsom DIY7297 Amp & Antipole PSU Destroyer OS Group Buys 237 16th October 2020 02:42 AM
Folsom EC7293: Battery/Solarcell Powered Feedback, 60/120w Destroyer OS Group Buys 71 25th November 2019 03:22 PM
2 lm3886 for 120w in 4ohm load audioloud Chip Amps 10 29th June 2004 08:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
