Group Buys Members group buys
Folsom EC7293: PVI Powered Frontend, 60/120w 8/4ohm
Old 12th September 2020, 08:41 PM   #281
yardbird is offline yardbird
Here tis-
L- 69.3v at PS, 7.52v at PVI, 23.95 at the resistor, DC OS- 0.0002v
R- 69.2v at PS, 7.47v at PVI, 23.95 at the resistor, DC OS- 0.299v
Couldn't get a solid measurement across the LED pins on either board. The R seemed to be making good contact but would not settle down.
Not sure why the regulator on the R is getting hotter (140 vs 98F). I'll reseat the heat sink.
JG
Old 14th September 2020, 04:12 AM   #282
Destroyer OS is online now Destroyer OS  United States
Destroyer OS's Avatar
Are the negative and positive voltages the same?
Old 14th September 2020, 07:57 PM   #283
(to PG)
Old 15th September 2020, 04:21 PM   #284
I got 35.3 to negative and 35.5 to positive on both channels.
Old 16th September 2020, 03:55 AM   #285
Any hot caps on either regulator board?
Carefully look for any burnt traces as well please.
Old 16th September 2020, 04:21 AM   #286
If you touch the input wires/connections on RCA, do you get AC on output? (hum)
As for offset, measure voltage to ground after the input cap, at pins 2 and 3 of first chip, and at the top ends of the 3,3k resistors above the dc trim pot.
Old 27th September 2020, 03:32 PM   #287
Reworked the light board and things are looking mostly better. While reworking he lightboard i also changed the amp chips, transistors and most of the smaller caps (not the aluminum ones).
Both channels are functioning. The light board regulator on L channel is about (130 F). Confirmed the heat diffuser was not resting on the light contacts. There also continues to be about .295 v at the speaker output on the L. The Right terminals are at 0.0001v. I measured DC offset after the input capacitor and it is 0002v. The three resistors next to the diode that I initially omitted are also warmer than the other channel (124 F vs 85 F) There are 2 little caps (can't remember value)next to the diode and 3 resistors. The one closer to the resistors is also warmer. I have the resistors and can swap those I don't have a spare cap. This was not one of the caps I changed (it was backordered. argh!). Should have ordered a similar product but NO!
Thanks Jeremy for your above and beyond assistance. Getting closer.
Old 27th September 2020, 03:54 PM   #288
My primary thought is checking resistor values because if you're using RN dales they are easier to mix up than other types.
You got the extra PVI board, right?
Old 27th September 2020, 04:31 PM   #289
mctavish is offline mctavish  Austria
Hey guys, just wanted to see if anyone else has not received the boards?
I am in Austria so maybe it takes a bit longer but they were shipped a while ago or?
Im itching to get started with this build!
Thanks!
Old 27th September 2020, 07:06 PM   #290
Yes, I got the board. Big thanks to you.
I replaced those resistors and one of the caps. Had some 10 Ohm (?) caps from the other board and measured them to see if they were in spec. Seemed to be. The resistors I changed are now running cooler. The regulator is not (130-140 F). Was fastidious (for me) to confirm the values of the 3 resistors. The two larger Dale resistors next to the larger (green on my board) cap are running warm (next to the ceramic cap). Might change those as well. The amp is running in now.
DC offset is still goofy. More likely, my measurement of the offset is goofy. Thought i had one board on target but it is now off. I am measuring at the side of the input cap near the PVI test points, right. negative to ground. The goofy board is still 0.295v. perhaps the potentiometer if fried? I have one of those as well.
Folsom EC7293: PVI Powered Frontend, 60/120w 8/4ohmHide this!Advertise here!
Folsom LOFI PCB's (Transformer board) & DC PCB's (PSU boards) Destroyer OS Group Buys 56 Today 10:08 AM
Folsom DIY7297 Amp & Antipole PSU Destroyer OS Group Buys 237 16th October 2020 01:42 AM
GB: Fo-Felix EMI Filter for AC mains 120/230v; By Folsom Destroyer OS Group Buys 201 14th August 2020 04:48 AM
Folsom EC7293: Battery/Solarcell Powered Feedback, 60/120w Destroyer OS Group Buys 71 25th November 2019 02:22 PM
2 lm3886 for 120w in 4ohm load audioloud Chip Amps 10 29th June 2004 07:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
