PCB for the HAWK A18 amplifier (+ FETs if required)
Hi guy's
For the schematics and part list pls look at post #10 and #11.
I have not included R1, C1 and C2 on the PCB as they are on the connector and in between the connector and the PCB in my setup.
Also changed R17 and R18 into 2 parallel resistors as I use a reed contact to switch the Iq and dont want to take the risk that this currentpath gets interupted with the result that the Iq is undefined.
Let me know if there are any other questions
Thanks!
FC-A 4,7M 16 Elko radial, 4,7 mF, 16 V, 105°C, low ESR, AEC-Q200 30
BC 556B DIO Bipolartransistor, PNP, 65V, 0,1A, 0,5W, TO-92 500
MKS2-100 1,5µ Folienkondensator, 1,5µF, 100V, RM5 15
ECWFD 4,7U 450 Folienkondensator, 4,7 µF, 450 V, RM 23, 110°C, 5% 15
METALL 160 Widerstand, Metallschicht, 160 Ohm, 0207, 0,6 W, 1% 100
MKP2-100 68N Folienkondensator, 68nF, 100V, RM5 15
FKP2-63 330P Folienkondensator, 330pF, 63V, RM5 30
BC 546B Bipolartransistor, NPN, 65V, 0,1A, 0,5W, TO-92 500
RAD FC 2.200/50 Elko radial, 2,2 mF, 50 V, 105°C, low ESR, AEC-Q200 60
MKP2-250 47N Folienkondensator, 47nF, 250V, RM5 100
METALL 10,0K Widerstand, Metallschicht, 10,0 kOhm, 0207, 0,6 W, 1% 100
METALL 221K Widerstand, Metallschicht, 221 kOhm, 0207, 0,6 W, 1% 100
METALL 100 Widerstand, Metallschicht, 100 Ohm, 0207, 0,6 W, 1% 100
LM 79L12 ACZ Spannungsregler, fest, -12 V, TO-92 10
METALL 3,83K Widerstand, Metallschicht, 3,83 kOhm, 0207, 0,6 W, 1% 100
METALL 2,80K Widerstand, Metallschicht, 2,80 kOhm, 0207, 0,6 W, 1% 100
METALL 604 Widerstand, Metallschicht, 604 Ohm, 0207, 0,6 W, 1% 100
METALL 665 Widerstand, Metallschicht, 665 Ohm, 0207, 0,6 W, 1% 100
METALL 475 Widerstand, Metallschicht, 475 Ohm, 0207, 0,6 W, 1% 100
METALL 402 Widerstand, Metallschicht, 402 Ohm, 0207, 0,6 W, 1% 100
METALL 80,6 Widerstand, Metallschicht, 80,6 Ohm, 0207, 0,6 W, 1% 100
METALL 10,0 Widerstand, Metallschicht, 10,0 Ohm, 0207, 0,6 W, 1% 100
METALL 22,1 Widerstand, Metallschicht, 22,1 Ohm, 0207, 0,6 W, 1% 100
LM 78L12 ACZ Spannungsregler, fest, 12 V, TO-92 15
TL 071 DIP Operationsverstärker, 1-fach, DIP-8 15
METALL 47,5 Widerstand, Metallschicht, 47,5 Ohm, 0207, 0,6 W, 1% 100
METALL 100K Widerstand, Metallschicht, 100 kOhm, 0207, 0,6 W, 1% 100
FKP2-63 150P Folienkondensator, 150pF, 63V, RM5 15
MKS2-100 100N Folienkondensator, 100nF, 100V, RM5 60
