Hi - I've stumbled across this thread as I'm searching for a DC voltage polariser with minimal forward volatrge drop. My search is based on LT4320.
My needs are simple: I need to connect a DC source of unknown polarity and ensure the correct polarity on the output with minimum volatge drop. The same as a reverse polarity protector. Is this 'over the top'? Are there cheaper/easier ways of achieveing this? The load will simply be a digital meter displaying the volatge. I appreciate that's going away from this thread.
Thanks in advance.
Thanks in advance.
Does anyone know where to get 8 off STL130N8F7 at the moment? If you have a few to sell please PM me
I think this should also be compatible, please check
https://www.mouser.com/ProductDetail/Infineon-IR/IRLB8743PBF?qs=9%2BKlkBgLFf0rfIKznQZ2TQ==
I'm looking for the SMT mosfets, the above is also on a 52wk leadtimeI think this should also be compatible, please check
I am trying to make 4 smd bridges for an amp, and 3 of them works great, but the fourth only seem to deliver half of the supposed DC voltage. I probably burned one or two of these mosfets, and I did not order extra. Now they are on backorder everywhere. What do you suggest in this situation? How can I even test the mosfets and the lt4320?
Any help appreciated.
This should be a good TO-220 MOSFET choice for the LT4320 CRC PSU board using 18VAC secondaries, yeah?
FDP085N10A-F102
For the through-hole version, I plan on grabbing these PDIP-8 AD LT4320.
FDP085N10A-F102
Boards are also available from PCB way: https://www.pcbway.com/project/shareproject/LT4320____diode_bridge_.html
Hi Prasi - I've been following this thread with interest. My needs are for a simple no-volt drop DC polarity checker, ie no matter which way 30vdc is connected it will be + and - on the output terminals. For that I don't need it to handle much current, maybe 100mA at most.Hello Gary, let me try it with dual secondary , 2 of the LT , and 8 of the mosfets but it wont be a compact replacement for SIP-4 rectifiers; rather it will be a regular PCB that needs mounting holes, run wires to bulk cap PCB, etc.
regards
Prasi
The SIP drop-in is excellent.
I do have another use, and that is rectification of up to 400vac to provide DC supply for valve amplifiers. That ideally would incorporate a ramp up to full volatge over, say 5 seconds, set by a resistor which could be chosen for different ramp up times. In that case, current is no more than 1A.
Would appreciate your comments. Thanks in advance.
I am trying to understand the 72v limitation of the LT4320 means.
Can this be used with dual secondaries of 34v?
(MOSFET CSD19503)
Is it 34v < 72v so it's okay?
or
Is it 34v + 34v < 72v so it's okay?
or
Is it (34v * 1.4) + (34v * 1.4) > 72v so it's not okay?
Have been trying to read and learn about it, but cannot find a straight answer.
Thank you,
David
(MOSFET CSD19503)
or
or
Thank you,
David
Davefred,
Go through the LT4320 datasheet, all the info is there.
https://www.analog.com/media/en/technical-documentation/data-sheets/4320fb.pdf
-One transformer secondary per LT4320 Ideal bridge.
-Center Tapped secondary is not compatible with LT4320
Yes min ac operating voltage is 6 VAC and min output DC voltage is 9VHello Prasi
greetings can this work on 9 volt AC 4 ampere current input current for a 5 volt 3 ampere
regulated linear supply for my rasberry pi DAC.
warm regards
Andrew
- Group Buys
- LT4320 based active rectifier
