Group Buys Members group buys
LT4320 based active rectifier
Old 21st April 2019, 06:36 PM   #11
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I am running into the same situation in making an all TH PSU using the active bridge.
The use of TH components requires double the parts and the parts are large.
Here is an example of a 10A capable active bridge (just one rail):
Here is the layout for the TH equivalent (dual rail) - it takes up 20% of the real estate whereas the SMT version is a small fraction of that and can be mounted on underside:
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st April 2019, 07:53 PM   #12
Lo_Tse is offline Lo_Tse  Canada
Originally Posted by prasi View Post
1. minimal power dissipation, no heatsink for rectifier, higher DC voltage output for a given AC voltage, etc
2. yes, it is a drop in replacement for SIP-4 type rectifiers.
3. THT option for LT4320 provided, MOSFETs are SMD, but will be simple to solder for anyone who has soldered SMD's before.
regards
Prasi
Yeah, the dual MOSFET is about the size of a smd opamp. Soldering should not be too bad. Using solder paste to stick the component to the board will help if you do not want to use regular solder. I prefer to use screw connectors than pins for AC though. Just curious what is the estimate of the current limit of the smd MOSFET. Thanks!
I have to agree with X and Prasi, using all TH components will increase the size (and cost) significantly. The 4320 is pretty expensive already
Old 21st April 2019, 09:24 PM   #13
Got Foam?
xrk971's Avatar
A Vishay-Siliconex SQJQ910EL (pictured above in the SMT implementation), can handle 70A, and up to 175C. Rdson of 8.6mOhm
https://www.mouser.com/datasheet/2/4...el-1110892.pdf
Ohmic heating = 70A^2 x 0.0086ohm = 42W (within rating for part of 62W to 187W depending on how cool you keep it).
For use on a PCB with just conduction to the PCB for cooling I would try to keep under 3W of dissipation. That's about 19A.
These are tough little MOSFETs.
Old 21st April 2019, 11:03 PM   #14
Thanks! X
Indeed, these are "powerful" MOSFET. You are talking about the smd version, right? Come to think about it, the size of the smd version of the MOSFET is only about 5 x 6 mm, 3 W dissipation is a lot for such a small device (please correct me if I am wrong) and there is no cooling. Is that OK?
However, I suspect that the typical current draw (for a class A amp running at 30 V) is probably under 5 A. So, the heat generated will be much lower.
Looking forward to your testing results!!
Old 22nd April 2019, 12:40 AM   #15
Got Foam?
xrk971's Avatar
At 4.35A they don’t even get warm. Direct cooling to PCB as heatsink can dissipate 1W to 2 mE no problem if there is more copper and vias to conduct heat away.
Old 22nd April 2019, 01:21 AM   #16
Great!! Thank you for the information. Good to know that!
Old 22nd April 2019, 02:06 PM   #17
prasi is offline prasi  India
prasi's Avatar
Originally Posted by gary s View Post
Hi prasi, do you think there would be more demand for your PCB if you made it using through hole components rather than SMT devices.
I assume you are trying to make it as small as possible.
Here is my all THT version of the rectifier, though small enough, its still cant replace the SIP-4 type rectifiers.
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 22nd April 2019, 02:19 PM   #18
Got Foam?
xrk971's Avatar
Nice TH layout, Prasi. Still, a very handy circuit to have on hand.
Old 22nd April 2019, 11:37 PM   #19
regards
Prasi
Hi, Prasi
Looks good! Just curious, are there any special reasons that you put 2 "diode bridge" together on one PCB?
Old 22nd April 2019, 11:53 PM   #20
prasi's Avatar
Hi Lo,
to make either +/0/- voltage by connecting in series or to get 2 V+ voltages.
LT4320 based active rectifierHide this!Advertise here!
CA3240 based precision rectifier gasboss775 Everything Else 10 23rd May 2015 10:42 PM
LT4320 active rectifier Conrad Hoffman Parts 13 10th February 2015 03:29 PM
Understanding an active full-wave rectifier 300b Solid State 2 29th September 2009 04:33 AM
An active box idea based on KEF Q1. Dxvideo Multi-Way 2 13th July 2009 06:53 PM
Looking for an active I/V stage for TDA1543-based DAC IpsilonSound Digital Source 21 17th June 2004 08:34 PM
Copyright ©1999-2019 diyAudio
