Group Buys Members group buys
LT4320 based active rectifier
Thread Tools
Old 2nd March 2021, 05:24 PM   #1071
prasi is online now prasi  India
ANALOG DESIGN
prasi's Avatar
Hi Patrick,
Good point. It was my laziness and rendering takes long time (I had an old i3 laptop, slower than snail then) . So didnt do latest rendering.
I am attaching here correct renders for THT rectifier version.
regards
prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 2nd March 2021, 05:35 PM   #1072
nattawa is offline nattawa  Canada
Originally Posted by Dan K View Post
Hello all, Can someone please direct me to the post where it's explained why one of these rectifiers can't be used by itself to supply a power amp from a single transformer secondary?
In This Post I tried to explain what I found to be why it doesn't work with center tapped secondary in constructing a split rail PSU.....it is because the bottom MOSFETs stay conductive most all the time during the AC cycle instead of turning on/off in sync with the top MOSFETs. I attempted a circuit trying to make it to work but it seems too much complexity would have to be involved in order to get it work properly under all possible conditions.
Old 2nd March 2021, 06:47 PM   #1073
ItsAllInMyHead is offline ItsAllInMyHead  United States
Originally Posted by prasi View Post
Hi Patrick,
regards
prasi
Hi Prasi -
You are very humble. I truly appreciate all the time and support you provide. It makes DIY projects much more approachable for beginners like myself.
With thanks!
Patrick
If you want a friend, feed any animal - Perry Farrell
  Reply to this post
LT4320 based active rectifierHide this!Advertise here!
Thread Tools
LT4320 active rectifier Conrad Hoffman Parts 14 24th February 2020 07:13 PM
CA3240 based precision rectifier gasboss775 Everything Else 10 23rd May 2015 10:42 PM
Understanding an active full-wave rectifier 300b Solid State 2 29th September 2009 04:33 AM
An active box idea based on KEF Q1. Dxvideo Multi-Way 2 13th July 2009 06:53 PM
Looking for an active I/V stage for TDA1543-based DAC IpsilonSound Digital Source 21 17th June 2004 08:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
