Group Buys Members group buys
The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
Old 5th July 2020, 12:48 PM   #971
thompsontechs is offline thompsontechs  United States
Freedom or Death
thompsontechs's Avatar
Andy,
Check your wiring on Q12, I had the same issue and I had it miss wired the flying leads, easy to do. As for the higher rail, that's about right without a load.
Who's your Daddy? Pappa of course.
Old Yesterday, 06:37 AM   #972
andyr is offline andyr  Australia
Originally Posted by xrk971 View Post
Hi Andy,
Please measure the voltages at all major nodes in the circuit (each pin of each transistor) and redline a schematic with those values. That way, we can troubleshoot with you. Itís like going to a doctor when you are sick and donít know why. Dr needs diagnostics: vitals, bloodwork, xrays etc.
So far, we know the negative rail is sick.
Hi X. OK, measurements as follows:
* traffo input to the -ve rail: 19.49 AC
* 2SC5200 pin 1: -26.9v DC
pin 2: -25v DC ... and dropping
pin 3: -26.9 DC
* BD140 pins 1 & 3: -26.7
(can't safely get to pin2.)
Andy
PS: Just now, I measured pin 2 of the 2SC5200 again - which is the -ve out voltage - and got -0.25v!!
Old Yesterday, 06:46 AM   #973
Originally Posted by thompsontechs View Post
Andy,
Thanks, JT. Just checked - the Q12 wiring is correct.
Andy
Old Yesterday, 05:19 PM   #974
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
It’s a slow effect. Look at your electrolytic capacitors C16, C18, something may be bad and takes time to show up. Looks like maybe a 30 second time constant?
What are other voltages when it goes bad? We need to know the voltage at the node of pin 3 of Q11.
Also accessible via the other parts connected to it. R16, C18, RV2.
The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB-7294c9af-c27b-4413-a3c9-cf47248f21af-jpeg
File Type: jpeg 7294C9AF-C27B-4413-A3C9-CF47248F21AF.jpeg (423.5 KB, 45 views)
XRKaudio https://www.etsy.com/shop/XRKAudio
Old Yesterday, 06:16 PM   #975
nicoch58 is offline nicoch58  Europe
will be a nice safety controll to avoid DC on speaker ....
Old Yesterday, 09:28 PM   #976
Got Foam?
xrk971's Avatar
The problem Andy has is a malfunctioning PSU. We have DC protection for speakers here:
Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GBHide this!Advertise here!
Mark Levinson 23.5 Schematic required for Power supply showing transformers and rect. susan211059 Solid State 0 23rd September 2009 11:00 PM
like peanut butter with chocolate d to the g Pass Labs 9 29th May 2008 02:10 AM
Int. Rect. Class D reference designs stoc005 Class D 3 17th February 2007 03:51 PM
ecc88 tube pover supply-rect. marijan Tubes / Valves 8 15th June 2005 09:50 AM
Mosfet Class A drive: Low voltage sharp attack Vgs :VS: Smooth gentle Vgs. Brian Guralnick Solid State 9 20th April 2003 02:11 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
