Group Buys Members group buys
The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB Please consider donating to help us continue to serve you.
Old 14th June 2019, 09:46 AM   #371
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
The SLB SR would be a great MoFo power supply, or even an ACA power supply.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 14th June 2019, 12:39 PM   #372
gary s is offline gary s  Australia
I think it would really up the performance of the ACA over the SMPS supply.
I have an ACA in use at the moment but with a linear PSU to replace the SMPS for the 24VDC supply. On my list to try would be a single rail SLB to power the ACA - will have to get 1 or 2 of these from your Etsy store.
The improvement the regulated linear supply gave over the SMPS was amazing, so would be interesting to see what further improvement the SLB will bring.
Old 14th June 2019, 10:06 PM   #373
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Added my name for the round 2 of the pcb (or rather added the board in my basket...)
SB
Old 14th June 2019, 10:34 PM   #374
Got Foam?
xrk971's Avatar
GB2 interest list.
analogdiy - 2 SLB - GB2
Bigaudioscotto - 2 SLB - GB2
Noviygera - 2 SLB - GB2
Asuslover - 1 SLB - GB2
Morde - 1 SLB - GB2
ppap64 - 6 SLB - GB2
axelcs -2 SLB - GB2
jameshunton - 2 SLB - GB2
80eengr - 2 SLB - GB2
douggoldberg - 1 SLB
sst4270 - 2 SLB
Algar_emi - 2(?) SLB
I think we have enough interest at this point for a GB2, please place a pre-order in my shop here. Make a note when you place your order what your DIYA handle is so that I can compare against this list. I would like to place the order for the boards soon.
Thanks,
X
Old 15th June 2019, 05:37 PM   #375
Got Foam?
xrk971's Avatar
GB2 status update:
Morde - 1 SLB - GB2
ppap64 - 6 SLB - GB2 - Preorder Placed
axelcs -2 SLB - GB2
sst4270 - 2 SLB
Algar_emi - 2 SLB
Old 15th June 2019, 05:41 PM   #376
Morde is offline Morde  Finland
Unfortunately I need to skip this one.
GB2 status:
axelcs -2 SLB - GB2
sst4270 - 2 SLB
Algar_emi - 2 SLB
Headphone amps: SE84, Salas DCG3, UTHAiM, PassDIY HPA, Pioneer Super Linear, XEN JLH
Power amps: M2x, UDNeSS
Old 16th June 2019, 07:45 AM   #377
Mr. X got me convinced to stay on board.
Morde - 1 SLB - GB2 - Preorder Placed
axelcs -2 SLB - GB2
sst4270 - 2 SLB
Algar_emi - 2 SLB
Old 16th June 2019, 08:09 AM   #378
808eengr is offline 808eengr
axelcs -2 SLB - GB2
80eengr - 2 SLB - GB2 - Preorder Placed
sst4270 - 2 SLB
Algar_emi - 2 SLB
Old 16th June 2019, 08:12 AM   #379
Got Foam?
xrk971's Avatar
Hey guys, we just discovered a small error with the orientation of Q5, the BD139 used in the SLB SR board. Pin 1 is denoted by the square pad, this will have the part’s front side in contact with heatsink if you use the large Fischer style heatsink. This part really doesn’t need such a large heatsink and a small sheet metal stamped or C channel aluminum one would work fine. Small heatsinks like that can be flipped around to the “back” of the BD139. Alternatively, one can mount a BD139 with its front towards the heatsink. Make sure you use a non conductive shoulder washer or bushing on the mounting screw to prevent it from contacting the metal pad on the back of the BD139.
My apologies for not catching this earlier - but should not be a problem as long as you mount the part with pin 1 on the square pad.
The SLB dual rail does not have this issue.
Old 16th June 2019, 11:06 AM   #380
Hi X, thanks for the addendum re the small error on the SLB-SR PCB.
I will need a couple of these which I believe are available in your Etsy store now.
Can you point me to the single rail schematic, parts list or BOM and stuffing guide - are these in this thread or another one?
The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GBHide this!Advertise here!
Mark Levinson 23.5 Schematic required for Power supply showing transformers and rect. susan211059 Solid State 0 24th September 2009 12:00 AM
like peanut butter with chocolate d to the g Pass Labs 9 29th May 2008 03:10 AM
Int. Rect. Class D reference designs stoc005 Class D 3 17th February 2007 04:51 PM
ecc88 tube pover supply-rect. marijan Tubes / Valves 8 15th June 2005 10:50 AM
Mosfet Class A drive: Low voltage sharp attack Vgs :VS: Smooth gentle Vgs. Brian Guralnick Solid State 9 20th April 2003 03:11 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
