The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
Joined 2010
Hello X and other builders. I am having a brain teaser with the dual rail SLB. Not with the actual schematics or layout, but with these 2 little helper boards I have purchased.
I would like to use a 4 pin molex box adapter with these blue helper boards.
Could some one tell me what the numeral 1 on the blue boards signifies ?
Am I correct in thinking that the molex box on the blue boards should be C-C-E-B starting from the upper left corner of the box proceeding clockwise ?.
I am also attaching a pic of the bottom of each of the blue heiper boards to hopefully explain my thinking about the molex pins.
Thanks a lot for the help.
MM
Joined 2010
Thanks IAIMH,
So for the N-BJT board using BCE: In the molex box 1 is B. Proceeding CW from 1 it is E, E, C
So for the P-BJT board using BCE: In the molex box 1 is B. Proceeding CW from 1 it is C, C, E
I don't know why the difference, but will be aware when running wires from the molex box to the SLB.
Thanks for the hint.
MM
