Group Buys Members group buys
GB for Simple Cap-Mx Regulated Low-Noise PSU
Old 28th May 2019, 12:51 PM   #81
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
No, it was just convenient to place underneath. You can bend legs on an axial and lay it sideways and solder it there as well. Thanks
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 28th May 2019, 01:47 PM   #82
jimk04 is offline jimk04  United Kingdom
Great thanks.
And sorry I forgot to ask.....is it ok to pre reg with lm317 before the SimpleMx to alleviate some heat from it ...so the voltage drop isn't so large on the SmX..?
I have some 317 boards...some toroids and rectifiers I would like to use up, but it will get me a higher voltage than comfortable to feed into the Smx to reg down to 5v for Rpi
Old 28th May 2019, 02:39 PM   #83
pcgab is offline pcgab  United States
How did I miss this?! These look perfect for my pi/dac set up.
If you some boards on hand, I would like to get a few from you. I can pm if need be, not sure if there is a current gb in progress or not.
Thanks!
Old 29th May 2019, 01:01 AM   #84
Got Foam?
xrk971's Avatar
Hi Pchab,
Sure, no problem. Will send invoice.
Old 11th June 2019, 05:38 PM   #85
Centurion53 is offline Centurion53  United States
Default C113
Need to ask a stupid question, I am not used to seeing capacitor values listed the way its shown on the BOM for C113, 2u2, what is this value?
Thanks,
Bill
Old 11th June 2019, 05:43 PM   #86
Thanks,
Bill
Similar to how some resistors are listed '2u2' would translate to 2.2uF.
Old 11th June 2019, 06:26 PM   #87
Got Foam?
xrk971's Avatar
Yes, the R (k or M), or u (Greek mu) or n (nano) or p (pico) is placed at the decimal.
For example 2R2 is 2.2 ohms, 2k2 is 2200 ohms, 2M2 is 2,200,000 ohms
2.2uF is 2.2 micro Farads, 2u2 is same, but with caps, M is sometimes used for Micro rather than Mega, so 2.2M is 2.2 micro Farads. And 2n2 is 2.2 nano Farads or 0.000022 Farads, and 36p is 36 pico Farads, etc.
Old 11th June 2019, 07:47 PM   #88
Default C113
Thanks, that was my guess but wanted to make sure.
Old 13th June 2019, 08:00 PM   #89
Originally Posted by xrk971 View Post
The 3A 5v regulator is a separate project - but let me see how we can make one. 3A at 5v is 15w upstream.
Is there a thread on this one yet?
Thanks!
Old 21st June 2019, 12:16 AM   #90
I got my two boards mostly assembled, waiting on some tpsa regs to arrive. So while I'm waiting for them to get here, I'm trying to figure out layout in my prototype chassis.
I'm using a 2x 9v/2x 15v toroidal transformer to feed into Salas' 'DC Flexy' boards that will feed into the cap-mx regulated supplies.
1 will feed the TDA1387 DAC Hat from Matt Garman.
1 will feed the Allo Kali re-clocker.
There is also a tpsa* regulated supply in there to feed the pi directly.
Hopefully the ebay tpsa regs get here soon, so I can wrap up and start listening!
The cap-mx supply boards are super easy to assemble, nicely laid out and a decent size. I used parts from my stash mostly, so some of the components choices may be a bit odd.
GB for Simple Cap-Mx Regulated Low-Noise PSUHide this!Advertise here!
simple low noise regulated supply sumotan Power Supplies 20 26th November 2015 03:00 PM
Low noise Regulated +-12v supply? Supergregg Power Supplies 4 6th May 2009 03:44 PM
Idea(s) for simple HV regulated psu rotation Tubes / Valves 6 21st February 2009 08:14 PM
Regulated DC PSU - Plain and simple please? GlidingDutchman Solid State 156 26th June 2008 12:20 PM
57 V regulated low noise Luis P. Solid State 8 7th February 2006 05:07 PM
Copyright ©1999-2019 diyAudio
