Group Buys Members group buys
GB for Simple Cap-Mx Regulated Low-Noise PSU
Old 2nd March 2019, 01:57 AM   #21
ericimage2 is offline ericimage2  United States
DrPro - 2 boards - USA
Vunce - 2 boards - USA
goldkenn - 4 boards - Hong Kong
Yatsushiro - 2 boards - France
Mindfunk - 4 boards - Germany
maartn - 3 boards - Netherlands
ericimage2 - 2 boards - USA
Old 2nd March 2019, 02:17 AM   #22
dtaylo3 is offline dtaylo3  United States
Could this be configured to do 5v @ 3 amp for powering a Asus Tinker Board SBC?
Old 2nd March 2019, 07:43 AM   #23
Roundtoit is offline Roundtoit  United States
Roundtoit - 2 boards - USA
Old 2nd March 2019, 08:27 AM   #24
Yatsushiro is offline Yatsushiro  France
No. See post 14, above GB for Simple Cap-Mx Regulated Low-Noise PSU
Old 2nd March 2019, 12:00 PM   #25
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
With some modifications and use of flying leads to an externally mounted regulator chip such as the LT1085 you can get 5v at 3A. The capacitance multiplier will need to be mounted to a substantial heatsink as well. 3A x 3.5v is over 10w dissipation on the IRF610. Assuming you are using 12v upstream then you have 8.5v downstream and another 10w will drop off from LT1085. Circa 20w total. That’s a big heatsink. You could use a DC-DC step down and take the 12v to 9.5v then that drops less heat across the voltage regulator but still same on IRF610 (they are designed for thatbso not a problem with sufficient heat sinking).
https://www.analog.com/media/en/tech...s/108345fh.pdf
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 2nd March 2019, 05:07 PM   #26
Kokanee is offline Kokanee  Canada
Kokanee's Avatar
Kokanee - 2 boards - Canada
Old 2nd March 2019, 06:37 PM   #27
Got Foam?
xrk971's Avatar
Hi Folks,
Thanks for the interest in this little PSU board. Give me a day or two and I will send out invoices for this board. Please send me your PayPal address if you have not already done so.
Thanks,
X
Old 6th March 2019, 04:01 PM   #28
Got Foam?
xrk971's Avatar
The boards have arrived and they look great. I will be sending out invoices shortly.
Old 7th March 2019, 06:57 AM   #29
Got Foam?
xrk971's Avatar
GB Status Update
DrPro - 2 boards - USA = Invoice Sent
Vunce - 2 boards - USA = Invoice Sent
goldkenn - 4 boards - Hong Kong = Need PayPal Address
Yatsushiro - 2 boards - France = Invoice Sent
Mindfunk - 4 boards - Germany = Need PayPal Address
maartn - 3 boards - Netherlands = Need PayPal Address
ericimage2 - 2 boards - USA = Need PayPal Address
Roundtoit - 2 boards - USA = Invoice Sent
Kokanee - 2 boards - Canada = Invoice Sent
Old 7th March 2019, 08:17 AM   #30
Received & Paid!
GB for Simple Cap-Mx Regulated Low-Noise PSUHide this!Advertise here!
simple low noise regulated supply sumotan Power Supplies 20 26th November 2015 03:00 PM
Low noise Regulated +-12v supply? Supergregg Power Supplies 4 6th May 2009 03:44 PM
Idea(s) for simple HV regulated psu rotation Tubes / Valves 6 21st February 2009 08:14 PM
Regulated DC PSU - Plain and simple please? GlidingDutchman Solid State 156 26th June 2008 12:20 PM
57 V regulated low noise Luis P. Solid State 8 7th February 2006 05:07 PM
Copyright ©1999-2019 diyAudio
