Group Buys Members group buys
Ideal bridge rectifier GB
Old 4th May 2019, 07:42 PM   #101
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Originally Posted by tvicol View Post
Joimonf, next ideal bridge will handle 200V @ even higher currents, while been very compact.
Tibi
Originally Posted by nautibuoy View Post
Sounds interesting!
I'm interested too.
Old 6th May 2019, 01:17 PM   #102
s610adam is offline s610adam  United States
Yeah this sounds great:
Hi Jan,
For tube fans I'll have discrete ideal diodes that will handle up to 450V at 6A.
Hope the end of soft tube rectification is near.
Tibi
Old 6th May 2019, 01:32 PM   #103
Bigun is offline Bigun  Canada
Bigun's Avatar
Who the heck designs tube amps running at 6A
I'd be interested in a solution for tube amps but there are already good reports from plain old diodes made from SiC and at 450V we don't care if we lose a few volts. However, I'm very interested in the soft-start option. I need more than 450V by the way - especially for choke loaded supplies.
Note: soft start is good for tube amps with EI transformers. The SS boys using humongous toroidal transformers need their soft start on the primary because the toroid itself is part of the start-up issue not just the caps. A soft-start on the secondary (as part of rectifier) will not fix their troubles.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 6th May 2019, 01:47 PM   #104
tvicol is offline tvicol  Europe
tvicol's Avatar
Ideal bridge rectifier GB Ideal bridge rectifier GB
I have made a synchronous diode/rectifier design that may work at 1200V @ 30A.
Wonder who need such ?
Tibi
Old 6th May 2019, 01:54 PM   #105
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
But what about hard tube rectification? These types of comparison would be interesting.
Old 6th May 2019, 01:59 PM   #106
Bigun's Avatar
Tibi
Are you offering them for sale, I have a project coming up with a Hamond 714 (510-0-510) power transformer.
Old 6th May 2019, 01:59 PM   #107
tvicol's Avatar
Even at higher voltages, synchronous rectification make sense due very low power dissipation, very small and compact circuitry and very low noise. Diode switching noise become very important at higher voltages.
However, that glowing tube has his magic.
Tibi
Old 6th May 2019, 02:00 PM   #108
Bigun's Avatar
with soft start and good diode turn-off behaviour there will never been a reason to use a tube rectifier
of course, you can't go retrofitting anywhere you feel like it - without series resistors the high current pulses of SS diodes will over-heat many transformers designed for tube rectifiers due to I*I*R heating of the copper windings
Old 6th May 2019, 02:03 PM   #109
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Synchronous rectification is the next step in audio (and not only audio),
Btw, do you know if synchronous rectifiers are used in automotive alternators as well? Are there any controller chips available?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 6th May 2019, 02:04 PM   #110
tvicol's Avatar
I made this only as an exercise and for fun. Only the mosfet alone is quite expensive. I do not think this will end to have any commercial success.
Tibi
Ideal bridge rectifier GBHide this!Advertise here!
bridge rectifier rock12 Power Supplies 4 15th January 2017 09:06 PM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Copyright ©1999-2019 diyAudio
