Group Buys Members group buys
Melbourne Daughterboard for M2X
Old 19th March 2019, 04:26 PM   #191
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
That’s fantastically quick work, JP! With some tweaks, we could probably bring this back to an “opamp” format - that is, all gain and compensation input coupling provided by user off-board. But it’s amazing that you got it to fit on two stacked wood pile boards. That’s not too big at all.
Please tell us what POPI stands for?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th March 2019, 04:38 PM   #192
JPS64 is offline JPS64  Germany
OPA = OPerational Amplifier and in German = grandpa, so Popi is nice!
JP
Old 20th March 2019, 06:05 PM   #193
jwjarch is offline jwjarch  United States
jwjarch's Avatar
Received my boards as well! That is one dense layout! Nicely done as always JPS and X! Thank you!
Old 20th March 2019, 06:29 PM   #194
Got Foam?
xrk971's Avatar
If you use the stuffing guide (pdf attachment) in post 1, it makes installing the parts correctly, much easier. Mine worked the first time with no issues. Here is re-post in PNG format for easier viewing/printing. Note the orientation of the leads on the vertically mounted resistors.
Melbourne Daughterboard for M2X-melbourn-th-v2-stuffing-guide-png
Old 22nd March 2019, 05:34 PM   #195
Got Foam?
xrk971's Avatar
First Sound on Melbourne and Yarra:
The YARRA Preamplifier/HPA for Melbourne DB Group Buy
The YARRA Preamplifier/HPA for Melbourne DB Group Buy-yarra-build-test-01-jpg
The YARRA Preamplifier/HPA for Melbourne DB Group Buy-yarra-build-test-03-jpg
Old 26th March 2019, 07:59 PM   #196
silasmellor is offline silasmellor  Denmark
Got my boards today, thank you x! I will build one set into a headphone amp preamp and mull over whether to use the other for an m2x
Old 27th March 2019, 03:23 AM   #197
batty is offline batty  Australia
My boards arrive safely Thanks
Townshend Rock II, My new TT since 1986.
Old 1st April 2019, 12:47 AM   #198
Got Foam?
xrk971's Avatar
I wonder if anyone has started building their Melbourne yet? It is a pretty simple project actually - just very tight layout, but that was necessitated by need to make it compatible with available board real estate on M2X main amp board.
A thought just occurred to me, one could use the Melbourne as a front end (input + VAS + driver stages) for *any* power amp output stage up to 50w. Just design the 4+1 bolt attachment points (extra bolt for GND) into your own PCB and concentrate on the output stage (whether it be push pull, quasi symmetric, SE Class A, etc.).
An interesting way to test the sound quality of different output topologies is to make several amps (all same rail voltage and same power) that all use same Melb front end.
Old 1st April 2019, 03:04 PM   #199
TungstenAudio is online now TungstenAudio  United States
I'm still building my M2x platform. I plan to start with the Ishikawa input stage and listen to that for a while to get a sense of how the M2 sounds in its basic form. I'm currently using a couple of ACAs in altered forms, so it will be interesting to experience a larger Papa amplifier.
The Melbourne's ability to add a tweakable amount of gain will come in handy. I plan to use this to get a little more signal boost from my Audible Illusions tube preamp. I'm thinking an extra 6 dB will be about right in addition to the 14 dB from the Edcor transformer. I plan to configure my second set of Melbourne daughtercards for the full 29 to 30 dB of gain in a Yara preamp that is capable of driving my F4 to full output.
Old 1st April 2019, 06:57 PM   #200
Got Foam?
xrk971's Avatar
I just tested my Melbourne at 30.6dB of gain. Sounds very nice.
Melbourne Daughterboard for M2XHide this!Advertise here!
Hi from melbourne sundays Introductions 7 24th October 2013 01:55 PM
O2 LiPo Daughterboard ryuji Headphone Systems 24 24th June 2013 07:26 PM
hi from melbourne, aus Bidtfaun Introductions 1 2nd April 2013 01:53 PM
What DIP plug to use for a daughterboard? leadbelly Parts 1 27th October 2004 07:53 AM
standard daughterboard size for an unsiversal preamp sonnya Solid State 7 9th January 2004 11:33 AM
Copyright ©1999-2019 diyAudio
