Group Buys Members group buys
Melbourne Daughterboard for M2X
Old 8th March 2019, 01:48 PM   #131
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Vunce has gone through the painful process of getting a Mouser shopping cart together for the Melbourne. It’s a lot of work to do this, so please join me in thanking Vunce for his efforts. This shopping cart is for 1 Melbourne, so double order for a pair. I still need to verify if all the pairs are here and correct - maybe someone else can help out with that.
Mouser Electronics
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 8th March 2019, 03:02 PM   #132
silasmellor is offline silasmellor  Denmark
Nice one, thanks!
Old 8th March 2019, 03:13 PM   #133
Got Foam?
xrk971's Avatar
I just received then order from this shopping cart and went through it compared to the schematic. There are a couple of changes that are needed:
R104 received was a 14.7k 1% when it should be 14.9k 0.1%
R106 received was 15k 1% when it should be 0.1%
C116 received was 33pF 16v C0G 1206 and should be 100v NP0/C0G this one needs to be replaced, as the low voltage rating may cause distortion when driving at higher voltages.
The two values R104/106 are needed to be precise 0.1% tolerance to tweak the output DC offset as close to 0mV as possible if running DC coupled mode. If you will be running AC coupled mode it won’t matter. Also, until one takes all the variations on the DC offset path, it may not matter as the voltage drop across the transistors also come into play. It’s not a big problem - and it will still work fine. You may get 15mV offset but that may not matter anyway.
For the output coupling cap, I spec’d a 47uF electrolytic. For those of you intending to drive the Edcor on the M2X, that’s a 600ohm load, so something like 220uF would give deeper bass flat to 5Hz vs 20Hz as you would have for 47uF. I picked the Nichicon Muse series 220uF 50v (UKZ1H221MHM) for this. It’s a bit big and will have to stand up kind of high to clear the other parts or you might even try 100uF which is smaller diameter. Although the 47uF will sound just fine too unless you are trying to listen to home theater rumble.
Otherwise the Shopping Cart above is fine.
Old 8th March 2019, 03:29 PM   #134
zman01 is offline zman01  Bangladesh
Originally Posted by xrk971 View Post
Vunce has gone through the painful process of getting a Mouser shopping cart together for the Melbourne. Itís a lot of work to do this, so please join me in thanking Vunce for his efforts.
Old 8th March 2019, 03:31 PM   #135
X,
Sure thing, takes quite a bit of time and effort to do this.
Vunce,
Thanks man!
Zia
Old 8th March 2019, 05:10 PM   #136
Vunce is offline Vunce  United States
Sorry about that X,
I should have picked up the tolerance change for R104/R106
Iíll edit the Mouser cart.
Old 8th March 2019, 05:38 PM   #137
Got Foam?
xrk971's Avatar
No worries, Vunce. As I said, we have to thank you for making the cart at all. Much easier to find a few items that are off than to find the link for 40 parts!
Thanks again, Vunce!
Old 8th March 2019, 09:30 PM   #138
gary s is offline gary s  Australia
A big thanks to Vunce as well from me for the time spent on the Mouser cart.
Old 8th March 2019, 09:45 PM   #139
Looking at Vunce's saved Mouser cart, some of the items selected are showing on back order and not currently available, one of the items is showing as a long lead time, so another alternative may need to be chosen.
Maybe Vunce, when you edit the cart based on X's changes, you might want to look at the BO items as well - just a suggestion, as I am sure members might want to order parts for their build.
Old 8th March 2019, 09:48 PM   #140
Thanks Gary S,
I'm on the hunt as I reply
Melbourne Daughterboard for M2XHide this!Advertise here!
Hi from melbourne sundays Introductions 7 24th October 2013 01:55 PM
O2 LiPo Daughterboard ryuji Headphone Systems 24 24th June 2013 07:26 PM
hi from melbourne, aus Bidtfaun Introductions 1 2nd April 2013 01:53 PM
What DIP plug to use for a daughterboard? leadbelly Parts 1 27th October 2004 07:53 AM
standard daughterboard size for an unsiversal preamp sonnya Solid State 7 9th January 2004 11:33 AM
Copyright ©1999-2019 diyAudio
