Group Buys Members group buys
DIY TDA1541A PCB "D3"
Thread Tools
Old 4th January 2021, 02:45 PM   #891
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Mark,
It is a very good point. You can successfully do this entire build with a fine tip. Doable, but difficult. Because of the affordability of air stations, I'm trying to push people to make the small investment with the idea that their success rate will be higher.
I did solder the U.fl's with a tip. Again, doable but you gotta be quick and good!
Greg
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, F4, DCB1, VHEX +, USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece (sold) TDA1541A D3, RH84, D3 Build guide
Old 17th January 2021, 07:05 PM   #892
androa76 is offline androa76  Slovenia
Hi Ryanj
Is it any D3 board for sale.
Thank you!
Old 18th January 2021, 02:12 AM   #893
ryanj is offline ryanj  Australia
ryanj's Avatar
Originally Posted by androa76 View Post
Hi Ryanj
Thank you!
Hi androa,
Order form link is on the first post of this thread.
Old 20th January 2021, 04:35 AM   #894
I did but no answer from you.
Old 20th January 2021, 04:52 AM   #895
ryanj's Avatar
Hi androa,
I'm just at work at the moment. I'll get on to it when I get home. Sorry for the delay.
Old 20th January 2021, 08:23 PM   #896
Is it possible to use Battery power supply for 26V input? What are minimal to maximal response of 26V voltage input?
Old 20th January 2021, 08:39 PM   #897
markos4553 is offline markos4553  United States
Hi Androa76,
Ggetzoff wrote up a build guide which should help you! Follow the link below and download the guide!
Good luck,
Mark K.
Old 21st January 2021, 06:42 AM   #898
Thank you.
At first i must confess i am not so that huuge fan of tda1541. Till now i didn"t hear any dac or cd player or modified that totally fulfil my apetite. Yes it is nice sounding dac, but not what i want. I listen very often to total dac that i like very much. And i have this sound as my reference in my head. For now i listen to es9038pro heavy modified dac because Ian combo is not enough for me. At some way i got Tda1541A and Tda1541s1 and D3 is first design that i am interested in.
Despite so many tda1541 designs approaches, it is very hard to read all treads and find out the reasons for using some ideas for D3 dac. For example why lp5907 ...4,5V. This reg is limited by max 6v, so using any Accu supply is impossible. Why not lt3042? and set to 5V ...why 4,5V. Maybe it is somewhere written ...? My idea is to run dac only battery supplied.
I have a lot of lifepo and lion accus that show good results at Ian streamer dac combination. Also our Rpi streamer is Accu suplied with linear regulators. This was the only way to totaly eliminated digitaliss , digital harsness that i very often hear at streamer (rpi or computer or comercial products) as a source.
As i see no specific ideas for using input board before i2s board... one possibility is to use Waveio as ryanj, or Jlsound usb that can be directly conneted to dac because it already has simultaneous output, but i will also like to use spdif and coax and i2s for amanero...
Old 21st January 2021, 09:26 PM   #899
ryanj's Avatar
Hi androa76,
If you would like to use a 5V reg for the attenuators just make sure it has the same pinout. The extra 500mV wont change the operation point of the attenuators very much. The LP5907 was used because it seemed to fit my design requirements and was recommended.
Old 28th January 2021, 05:30 AM   #900
Understand. Do you have any recommendation for silvered ufl cables for connection data lines? Thank you.
DIY TDA1541A PCB "D3"Hide this!Advertise here!
Thread Tools
"Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Group Buys 1613 24th April 2019 02:56 AM
TDA1541A "piggybacking" on analog metric pcb? Mayday Digital Source 43 4th June 2012 09:55 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 04:21 AM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
