Group Buys Members group buys
DIY TDA1541A PCB "D3"
Thread Tools
Old 24th November 2020, 10:06 PM   #861
chromenuts is offline chromenuts  United States
@Mark Thanks for chiming in towards the end to help me sort out the final bits!
@Ben Thanks for the information on the wire. There is still an eBay seller in Bulgaria that is offering a variety of gauges in the Isotan Constantin wire.
Some listings are describing the wire as ďoxidizedĒ ...just wondering what that is all about as I thought something like this would have an enamel coating or similar. Iím assuming it has some sort of coating. Part of the description gives the resistance per meter.
Old 25th November 2020, 10:25 AM   #862
ryanj is offline ryanj  Australia
ryanj's Avatar
HI Nilton,
So, could you consider D3 design as a Direct Interpolation DAC?
No, IIRC Direct Interpolation was a type of over sampling but done in the analogue domain.
Only output transformers instead of tubes? I really like to try a Lampizator 6N2P tube stage... Have you ever tried this?
Yes i've tried this tube stage and it sounded fine, but I couldn't recommend a high voltage OP stage - too much risk involved for a newbie - unless of course you have had experience with high voltage...
Transformer IV is great - no power supplies, sound great, and only require one cheap resistor. Member bisesik on this forum makes very nice transformers for a good price. Ivan has recently been playing around with the TDA15451A and has specially made transformers to suit the 1541A. Nanocrystalline core, very low DCR, excellent frequency response and low losses. At 20Hz with a 10k load resistor its only down -0.6dB and im getting around 3.7Vpp into my F5 which is enough for my speakers to give a decent thumping bass and annoy the neighbours.
I did not find so many players/transport units with i2s outputs, and I need a versatile dac so that I can switch it from transport/streamer to TV, to PC and also to my cell phone by bluetooth. Is it possible to have I2S, SPDIF, USB and Bluetooth inputs? If it is possible, SIM would be used only when I2S input is selected?
Have a search for USB to I2S convertors.
What Is everyone else using? Im still using an old WaveIO connected to my laptop running jriver, spotify and tidal.
Old 25th November 2020, 10:39 AM   #863
ryanj's Avatar
I've still got a lot of CuNi44 if you want some.
ENAMELED CuNi44 0.1mm diameter (Constantan, Isotan) Resistance wire
Old 26th November 2020, 06:30 AM   #864
manniraj is online now manniraj  India
A noob question and sorry if this has been answered somewhere in this long thread, what is the difference between the V1/V2 of the i2s2sim boards? Is the V2 just the latest version with more components compared to V1 as far as the pricing goes both the PCB boards are at the same cost.
Old 26th November 2020, 08:21 AM   #865
ryanj's Avatar
V1 is the original circuit ecdesigns shared.
V2 has extra outputs - 4 x LE, 4 x BCK, 2 x DL, 2 x DR, 2 x DR inverted, and 2 x DL inverted. Adding the extra outputs and inverted data outputs enables balanced operation. I have tested a total of 4 x D3 PCBs being run at 176k sampling rate in balanced mode.
So the V2 is better value with the extra functionality. But with the V1 you are getting the original shared circuit from EC.
Old 26th November 2020, 09:06 AM   #866
Thanks Ryan.
Old 26th November 2020, 07:29 PM   #867
ryanj's Avatar
Originally Posted by ryanj View Post
HI Nilton,
Correction - Direct Interpolation is very similar to Linear Interpolation
Originally Posted by ecdesigns View Post
Hi, Uchi Deshi
Thank you for your reply
Direct interpolation uses at least 2 DAC's, this creates 88.2KHz virtual sample rate and doubles the resolution. The Quad Direct Interpolation DAC creates 176.4 KHz virtual sample rate and results in 18 bit resolution. And yes sure you can use more DAC's in parallel, 8 DAC's will create 352KHz virtual sample rate and so on. How does it work? It involves slight timeshifting (delay) of both Data and Wordselect and connecting 2 pair of DAC outputs in parallel, then these two are fed into a differential amplifier after I/V conversion. So this system only needs 4 I/V converters. The easiest way of visualizing this system is comparing a 1 cylinder engine with say a 4 cylinder engine. The 4 cylinder engine runs much smoother and achieves much higher revs than a 1 cylinder engine would. Now the DAC's are the pistons, the crankshaft is the output stage and the ignition is the timeshifting. So all 4 DAC's receive their DATA in sequence (not simultaneously). So they output their sample on slightly different moments in time (one clockpuls after wordselect changes) and thereby creating addittional interpolated steps i.e. increasing the resolution. So basically it's a quite simple technique. Since an added sample always stays in the timeframe (64 clockpulses) of the original (large) sample, there is no phase shift. Schematic diagrams will follow.
Old 30th November 2020, 08:26 PM   #868
Hi Ryan
I was thinking about ordering some of the Constantan wire to try making some iv resistors...Iíll PM you to discuss it.
I finally finished up the casework and got a lid on the D3. I took a bit of time rearranging my system to try and have my digital front end organized nicely.
Itís been probably about a year of planning and building to get here and finally be able to sit back and enjoy it.
I have been enjoying it a lot over the holiday weekend here.
Iíve attached a few pics of it and the rack (I hate the rack and it needs a proper replacement...sooner or later).
I am using a rebuilt Mac Mini to stream from iTunes with an App called Bitperfect that loads the music into RAM for playback and prevents the OS from messing with the file resolution. It has a few glitches now and again, but I can live with it for now.
One of the best decisions I made was to buy a Luna Display dongle to interface my Pro Pad with the Mini. It has been seamless and completely stable. It allows me to run the Mini headless and have complete control over any software I would want to use on the Mini from my Pro Pad.
Iím also very happy with the Shigaclone project. It sounds great and allows me to just throw in any disc I have been too lazy to rip because Iím busy trying to download new stuff all the time.
I will be going back into the D3.
Iíve a slightly used pair of bisesikís transformers I negotiated a deal on.
My understanding is that they are wound optimally to be used with a pair of TDA1541A in differential mode.
Iíll need some guidance with the wiring most likely.
File Type: jpg 7C82AED2-4429-4E5D-889C-036BCED58874.jpg (728.5 KB, 216 views)
File Type: jpg F4F27952-8638-4DC5-9CB3-F0BA838C0000.jpg (758.9 KB, 205 views)
File Type: jpg C3B0D9CF-7C02-41C9-A50D-9739CDC5EFA0.jpg (487.8 KB, 202 views)
File Type: jpg 639E914A-0AC7-4C5C-A0F1-EB502BE214A1.jpg (650.0 KB, 199 views)
Old 1st December 2020, 07:24 AM   #869
ryanj's Avatar
Hi Kevin,
Well done, case looks awesome! You're whole setup looks very nice indeed.
What ratio transformer are you getting from Ivan?
Hi Ryan
Old 1st December 2020, 02:25 PM   #870
Thanks Ryan...here is a pic from the listing.
Iím not sure what all the info on the top line is about.
The bottom line indicates 0.5 + 0.5:22
File Type: jpeg 239752EF-885F-46CF-8365-476CB90D8903.jpeg (190.0 KB, 163 views)
DIY TDA1541A PCB "D3"Hide this!Advertise here!
Thread Tools
"Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Group Buys 1613 24th April 2019 01:56 AM
TDA1541A "piggybacking" on analog metric pcb? Mayday Digital Source 43 4th June 2012 08:55 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 03:21 AM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
