Group Buys Members group buys
DIY TDA1541A PCB "D3"
Old 2nd February 2019, 02:21 AM   #61
ryanj is offline ryanj  Australia
ryanj's Avatar
Default update
Hi All,
Just a quick update of where im at with the D3 design.
I've had a few computer issues which stopped the design process in its tracks for a while but i've recently picked it up again.
In this design i've included a position for an IV resistor, and also a basic CCS from +5V to supply 2mA for the offset output current - this not only sounds better than a k216 CCS but is more temperature stable.
Attenuator supply has been simplified.
Bit current supply pins have a position for 100uF 6.3mm/2.5mm pitch caps and also a 1206 100nF NP0s to go in parallel.
Old 2nd February 2019, 10:45 PM   #62
wlowes is offline wlowes  Canada
wlowes's Avatar
Looks good..
I might be the only one seeking this so not suggesting a design compromise...
For those of us who already have +5v, -5v, -15v supplies with sorted supply and discrete regs (salas shunt), would it be possible to drop the power supply parts from your pcb and inject the supply at the output pins of your regulators?
On one hand I can't see why not...
OTOH, perhaps better it's better to have shorter path from on board reg to TDA1541a? I recall Oliver transitioning from similar on board regs to discrete salas shunts and claiming victory. So I figure if I've got them then may as well use them.
Old 3rd February 2019, 02:36 AM   #63
ryanj's Avatar
Hi Walter,
If you left out the whole power supply section on the PCB then you could tap into the separate supplies. But you could not power the on board regs individually if you populate them because the -5 and -15 are actually stacked and in series. (-5 and -10 stacked).
I remember looking at olivers shunt regs, as I recall he did not use a pass PNP in conjunction with the TL431, which alters the output impedance from around 15 milliohms to around 3 milliohms with the PNP.
In the past I've also used the salus shunts to power the 3 supplies but actually prefer how I have it now with the "zenner string".
Old 3rd February 2019, 07:48 AM   #64
Konzol is offline Konzol  Hungary
markos4553 x1
BarG01 x1
sthcoaster x2
av-trouvaille x1 (possibly more)
kenlaumm x 2
Si_jopie0382 x 2
pistollero x 1
nick696 x 1
leejh x 1
ekidnah09 x 1
wlowes x 1
Greg Stewart x 1
Ben Mah x 1
dabore84 x 1
RobA x 1
Harolda x 2
Ernesternest x 1
sampsonite x 2
Sonicmasala x 1
bigturtle x 2
cristianr x 1
Konzol x 1
Old 3rd February 2019, 04:37 PM   #65
wlowes's Avatar
Originally Posted by ryanj View Post
Hi Walter,
Great explanation. Thanks
Old 4th February 2019, 08:03 PM   #66
markos4553 is offline markos4553  United States
markos4553 x1 (possibly more)
BarG01 x1
sthcoaster x2
kenlaumm x 2
Si_jopie0382 x 2
pistollero x 1
nick696 x 1
leejh x 1
ekidnah09 x 1
wlowes x 1
Greg Stewart x 1
Ben Mah x 1
dabore84 x 1
RobA x 1
Harolda x 2
Ernesternest x 1
sampsonite x 2
Sonicmasala x 1
bigturtle x 2
cristianr x 1
Konzol x 1
DIY TDA1541A PCB "D3"Hide this!Advertise here!
"Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Group Buys 1607 19th October 2018 07:56 PM
TDA1541A "piggybacking" on analog metric pcb? Mayday Digital Source 43 4th June 2012 09:55 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 04:21 AM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
Copyright ©1999-2019 diyAudio
