Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Group Buys Members group buys |
#461 | |
Airline Pilot-If it's not Boeing I'm not going. Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece |
#462 |
Done.
As promised some photos The front is from a traditional Lao loom so the wood is probably teak, at least that bottom piece looks teak-ish not sure about the top rail. I added some breathing holes to the top and because the whole front is porous on account of it being the loom piece it should draw some air there. I am happy how they came out using the step bit on my hand drill. Before closing it all up I put in the S1 and heatsinked it; added some hot glue where I've soldered wires directly to the I2S > Simultaneous board; and slapped some SilentCoat around the chassis to make it nice and dull. Hope I won't have to open it up for a long while - don't think there is anything else I want to do to it right now. But never say never. I've got a second D3 board .... parallel? differential? ![]() Very happy. Big thanks to Ryan for his support. What's next? Last edited by sthcoaster; 23rd November 2019 at 10:43 AM. |
#463 | |
#464 |
Hi group,
Can each of you sound-off on how you did your U.Fl male smd connectors? I'm assuming hot air rework or oven? Cheers, Greg
#465 |
Hi Greg,
I have a budget hot air rework station that I purchased from Amazon a few years ago. it looks just like this one: https://www.amazon.com/Tek-Motion-Di...BR32ZV5YEG7EKV I used it to put together both my D3 and I2S to Simultaneous boards. Ben |
#466 | |
Fantastic build Clayton, very neat, the face plate is a nice creative touch.
Im testing out a differential setup in my DAC at the moment, its sounding pretty good. I made another I2S2SIM PCB that has inverted data output. The output of the D3 is going into a transformer with the center tap going to a -4mA CCS with an IV resistor of 60R on each output. Quote:
#467 |
I usually tin the signal pad first with enough solder to tack the connector on the pads, then solder the ground pads and then go back to the signal pad with some flux and a little more solder. I use .48mm 5 core solder. I set my iron to about 330C.
#468 | |
Canot wait to see photo of differential setup Last edited by Myint67; 25th November 2019 at 04:43 AM. |
#469 |
A bit of solder paste and then use an iron. If I need a bit more solder then I use 0.5 solder like Ryan has also suggested. I have hot air station but have found that I still revert to using the iron.
#470 |
Thread | Thread Starter | Forum | Replies | Last Post |
"Reference" TDA1541A DAC with I2S-BUS architecture | dvb projekt | Group Buys | 1613 | 24th April 2019 02:56 AM |
TDA1541A "piggybacking" on analog metric pcb? | Mayday | Digital Source | 43 | 4th June 2012 09:55 AM |
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs | Thesoundmen | Swap Meet | 1 | 27th July 2011 04:21 AM |
A real DAC Philips TDA1541A "Double Crown"? | dbhh | Digital Source | 17 | 7th May 2004 06:15 AM |
New To Site? | Need Help? |
