Group Buys Members group buys
DIY TDA1541A PCB "D3"
Old 8th November 2019, 01:26 AM   #331
ggetzoff is online now ggetzoff  United States
ggetzoff's Avatar
Originally Posted by Ben Mah View Post
I would suggest you try to determine which board is causing your problem. Have you tried your D3 with I2S input? If not, change the D3 board to I2S and connect your USB to I2S board to the D3. If that is successful, then you know that the issue is with the Simultaneous board. If I2S input does not work, then you have an issue with your D3.
How do I change the D3 for I2s?
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece
Old 8th November 2019, 01:44 AM   #332
Ben Mah is offline Ben Mah  Canada
On the back of the board, there is J1, J2,and J3. Put solder on J1 for I2S, or solder on J2 for Simultaneous. That is shown on the back of the board. For Simultaneous, did you solder J2?
If you are changing inputs, you have to desolder the input that you are changing from.
Old 8th November 2019, 01:49 AM   #333
ggetzoff's Avatar
Ben,
Uh no. I don't think I set a single jumper.
Vancouver, love that city!
Old 8th November 2019, 02:29 AM   #334
Yes, but I am in another great city right now. I'm in San Francisco for Burning Amp.
Old 8th November 2019, 03:34 AM   #335
ggetzoff's Avatar
I'm debating whether to come.....I can make it for Sunday. Just haven't decided.
Old 8th November 2019, 09:37 AM   #336
ryanj is offline ryanj  Australia
ryanj's Avatar
Originally Posted by ggetzoff View Post
Ryan,
Everything is powered but Im not getting any audio, only digital noise. Im running an XMOS USB to I2S -> I2S to Simultaneous board -> Distinction.
Im using a tube output stage, so R35, R36 not populated. Those pads are not shunted when unpopulated, correct?
Like I said earlier, I was able to trim the offset out.
Greg
Hi Greg,
You can leave R35 and R36 unpopulated, they are an option for an IV resistor.
If your getting digital noise check whether you have the outputs connected to the correct inputs, and if you haven't already make sure you put a solder blob on J2 when running in simultaneous mode.
Old 8th November 2019, 01:29 PM   #337
ggetzoff's Avatar
Originally Posted by ryanj View Post
Hi Greg,
Ryan / Ben,
I put a shunted J2, still the same. Can you guys look at my USB to I2S converter?
Singxer C-1 XMOS Digital Interface XU208 U8 Upgraded Femtosecond TCXO Audio | eBay
I'm next going to try I2s in lieu of Simul. With I2S I go directly from the converter to the D3, correct?
Greg
Old 8th November 2019, 02:32 PM   #338
Hi Greg,
I don't have a Singer C-1 but after searching and reading about the Singer on the net, the Singer outputs I2S. This page shows the I2S output pins and power supply connection and Ground pins:
Singxer C1 (NDK/EPSON)- USB Digital Interface Board – XU208 chip | Kitsune HiFi - HoloAudio USA
Yes, for I2S, connect the Singer directly to the D3.
Ben
Ps: The Singer ground needs to be connected to the D3 if in I2S or connected to the Simultaneous board if using Simultaneous. From Simultaneous to D3, if you are using the connectors, Ground is already included in the cables.
Old 8th November 2019, 07:14 PM   #339
ggetzoff's Avatar
Hi Greg,
Singxer C1 (NDK/EPSON)- USB Digital Interface Board XU208 chip | Kitsune HiFi - HoloAudio USA
Ben
Ben,
I never connected ground from the Singxer to the simultaneous, I checked the ground pinout and discovered a solid ground all the way to the D3. However, I will do as you say and add a ground from the Singxer to the Simultaneous board.
It looks like my tube I/V has a an approximately 600R input impedance. This is the Abbass audio I/V which I know has been used with this dac board before. What should input the input impedance be? Approaching zero?
Thanks,
Greg
Old 8th November 2019, 08:25 PM   #340
I don't think you want zero input impedance. I believe that would dump the signal to ground.
DIY TDA1541A PCB "D3"Hide this!Advertise here!
"Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Group Buys 1613 24th April 2019 02:56 AM
TDA1541A "piggybacking" on analog metric pcb? Mayday Digital Source 43 4th June 2012 09:55 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 04:21 AM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
Copyright ©1999-2019 diyAudio
