Group Buys Members group buys
DIY TDA1541A PCB "D3"
Old 18th July 2019, 05:32 AM   #141
Myint67 is offline Myint67  Singapore
Hi can I use Ian fifo pi ? How to wire with I2s ?
Old 18th July 2019, 08:11 PM   #142
Ben Mah is offline Ben Mah  Canada
Connect the I2S out from the Fifopi to the I2S in on the Distinction board. To select I2S on the Distinction board, put a blob of solder on 'J1' on the back of the board.
Old 22nd July 2019, 09:00 AM   #143
sthcoaster is offline sthcoaster  United Kingdom
Boards received this morning, Thanks Ryan
Old 22nd July 2019, 09:57 AM   #144
ryanj is offline ryanj  Australia
ryanj's Avatar
That was quick!
Old 23rd July 2019, 09:10 AM   #145
Originally Posted by tomtest View Post
But my findings in the LtSpice simulation and the new circuit picture from Ryan shows 2x34V are correct. (Ryan please correct me if I am writing something stupid )
Ryan, as you know I've tried unsuccessfully to make this circuit work using 24v transformer. Now that I am looking for 34v transformer with CT as per your diagram I cannot find any suitable transformer (ie. 68v series 34v parallel or 34v-0-34v) the only one I can find on usual suppliers is a non-stocked item about US$200 and rated at 1700VA. I will be very interested to learn about the transformer you have been using.
I think for many us trying to do this project the PSU aspect is proving tricky.
Thanks.
Old 23rd July 2019, 09:52 AM   #146
tomtest is offline tomtest  Germany
Thanks.
Hi Clayton,
Here you can find such transformers :
TTSA0030 - Transformer AUDIO TSA30VA - voltage to 50V - Shop Toroidy.pl
As example 30VA but you can get a lot of others, and then you can choose 2x34V. They will cost around 24,-€ without shipping.
I have ordered one too but it has not arrived until now.
If I have gotten it and build the circuit i will inform you about my findings.
In the meantime I tried out to power up the D2 with two UltraBIBs from Salas with a transformer 2x15V connected to one + and one - PCB with connection between both 0 on the output and using only the + and - output (each adjusted to 13 between +/- to 0, so you get 26V between + and -).
A third UltraBIB is used for the 8V.
It works without any problems, but the simulations of Ryan circuit shows a clean output so I am curious how it will influence the sound.
As told I will keep you informed.
Hope that helps a little bit.
André
Old 23rd July 2019, 10:54 AM   #147
ryanj's Avatar
Thanks.
Hi Clayton,
The transformer im using is a "F-212Z" from Triad. It is a 24-0-24 24VA.
In the schematics I posted the model says 34V as a peak voltage not the RMS.
What exactly was the issue when you tried building this circuit previously?
Old 23rd July 2019, 12:27 PM   #148
Originally Posted by ryanj View Post
Hi Clayton,
I couldn’t get the voltage low enough when testing my with load resistor. From memory I could only get it down to 29v.
Old 23rd July 2019, 12:31 PM   #149
Thanks Andre. I had forgotten about Toroidy. Have bought from them before.
I see Ryan’s reply that he is using 24-0-24
I need to play around with my setup again and check the Darlingtons are still ok
I have been using 0-24v with full rectifier. Will try other things.
Hi Clayton,
André
Old 23rd July 2019, 11:01 PM   #150
ryanj's Avatar
Clayton,
Try using just 2 diodes in your rectifier instead of 4.
DIY TDA1541A PCB "D3"Hide this!Advertise here!
"Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Group Buys 1613 24th April 2019 01:56 AM
TDA1541A "piggybacking" on analog metric pcb? Mayday Digital Source 43 4th June 2012 08:55 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 03:21 AM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
Copyright ©1999-2019 diyAudio
