Group Buys Members group buys
DIY TDA1541A PCB "D3"
Old 16th July 2019, 09:39 AM   #131
ryanj is offline ryanj  Australia
ryanj's Avatar
Default PCB Orders
All PCBs have been posted.
Old 16th July 2019, 09:57 AM   #132
bisesik is offline bisesik  Kazakhstan
Output transformers for DACs
Hi Ryan! Can you say, is it possible to avoid the current offset elements (TR1\C56\R32 and TR2\C57\R33) if to use your boards in differential mode with transformers?
I mean the following connection:
Have you tried that or not? Thank you!
BR, Ivan
Old 16th July 2019, 10:19 AM   #133
ryanj's Avatar
Attachment 768589
BR, Ivan
No I havnt tried using a transformer for my output stage. I believe Batteryman and Koldby have had experience with transformers, they would be able to give you some advice.
I'd say it would depend on the resistance of the coils. I've found that having DC on AOL and AOR has a negative impact on the SQ, but this is using the CEN passive IV, so it may have a different impact. Not sure. Sorry im not much help.
Old 16th July 2019, 10:25 AM   #134
Anyway thank you Ryan! Hope Batteryman or Koldby can tell more...
Old 16th July 2019, 10:27 AM   #135
ryanj's Avatar
Batteryman talks about it here -feed the current into the CT
And here
Old 16th July 2019, 05:11 PM   #136
Ben Mah is offline Ben Mah  Canada
Thank you, Ryan.
Time to order some parts. Those 22uF acrylic metallized capacitors (C6, C14, C20) sure are pricey:
16MU226MD35750 Rubycon | Capacitors | DigiKey
And only available at Digi-Key, not stocked by Mouser.
Old 17th July 2019, 08:55 AM   #137
ryanj's Avatar
Originally Posted by Ben Mah View Post
Thank you, Ryan.
Yes they are, but they are worth every cent. I tried using different caps but didn't get anywhere near the same SQ.
Old 17th July 2019, 09:22 AM   #138
pistollero is offline pistollero  Portugal
Hello , can someone tell the total price of the bom?
Thks
Old 17th July 2019, 10:15 AM   #139
ryanj's Avatar
Total cost of BOM is $155 AUD
Old 17th July 2019, 12:43 PM   #140
When I order components I usually order extras, especially for the smaller sized smd components. The smaller sized resistors and capacitors can be easily lost so spares are handy. It saves on reordering time and shipping cost for orders of less than $100 if buying from Digi-Key or Mouser.
I will not be ordering extra C4 C14 C20 though. They are big enough so I will be able to see them if I drop them. And I will be ordering the Ryan recommended Rubycons.
So for me the BOM cost will be a bit more to account for possible component loss due to my clumsiness or poor soldering technique.
Although for the components that are required in quantities of seven or eight, it may not cost any more to buy 10, so the spares are free.
DIY TDA1541A PCB "D3"Hide this!Advertise here!
"Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Group Buys 1613 24th April 2019 01:56 AM
TDA1541A "piggybacking" on analog metric pcb? Mayday Digital Source 43 4th June 2012 08:55 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 03:21 AM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
Copyright ©1999-2019 diyAudio
