Group Buys Members group buys
Simple High Performance DC Coupled Class A HPA with sub PPM THD
Old 27th June 2018, 05:49 AM   #71
pstech is offline pstech  United States
Badboygolf16v - 1 pair
Dabore84 - 1 pair
funch - 1 pair
kartk - 1 pair
Yourownbuzz - 1 pair
BabyDontHertzMe - 1 pair
Stellarelephant - 1 pair
passive420 - 1 pair
Pinnocchio - 1 pair
vvs7 - 2 pairs
Gwrskien - 1 pair
Ernesternest - 1 pair
jwjarch - 1 pair
ermine22 - 2 pairs
Morde - 1 pair
S610adam - 2 pair
pstech - 2 pair
Old 27th June 2018, 01:06 PM   #72
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by stellarelephant View Post
Wow, X, looks like you nailed it!
Thanks. To get this performance requires use of the TP7A4xxx LDO regulaors which are only available in quad flat pack with no leads and underside power pad for heatsink. They are rather tricky to solder (must be done with reflow) as needs a hot air gun from above and a hot plate from below, plus the pin pitch is 0.5mm. They don't make them in a larger package like SOTxxx or even SOIC where legs are visible. JPS64 is looking into getting some made to conform to a standard larger trough hole adapter board to resemble an LM3x7 TO220. One could use an LM317N or LM337N in SOT223, but the noise is about 10x higher at 38uV rms vs 4uV rms.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 27th June 2018, 01:39 PM   #73
badboygolf16v is offline badboygolf16v
Could they be ordered from someone like say www.ldovr.com? Maybe we could do a GB for them?
Old 27th June 2018, 01:55 PM   #74
Got Foam?
xrk971's Avatar
I have bought one from there before - they are kind of pricey at $23 ea. Some Chinese ones are now in the circa $8 range (but not TO-220 pin compatible -but that's ok).
TPS7A3301 -5V -9 -12 -15V -18V 1A Ultra Low Noise LDO Negative Voltage Regulator 699924389058 | eBay
TPS7A4700 Low Noise Power Module DC-DC 3-36V to 3V 3.3V 5V 12V 15V 1A Adjustable 699901905578 | eBay
So these are also an option.
Old 27th June 2018, 02:11 PM   #75
JPS64 is offline JPS64  Germany
In progress...
JP
Old 27th June 2018, 04:23 PM   #76
Got Foam?
xrk971's Avatar
Hi JPS64,
This looks great. Can you please add a M3 screwhole so that we can bolt a TO220 heatsink to make contact with thermal pad vias on the back?
Thanks,
X
Old 27th June 2018, 08:29 PM   #77
Hi X,
to small for M3 screwing. I´m prefering folling:
- SK 104 25,4, Extruded heatsinks for PCB mounting, Heatsinks f.cool, Fischer Elektronik
- https://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/A06/Retaining%20springs%20for%20transistors/PR/THF104_/$productCard/parameters/index.xhtml
Isolating electrically the PCB using foil.
JP
Old 27th June 2018, 09:40 PM   #78
Got Foam?
xrk971's Avatar
Hi JPS,
Yes, those are similar the heatsinks I get from eBay for about $7 for 10. I would probably use silicone TO220 insulator sheets or one layer of Kapton tape works too.
Thanks,
X
Old 27th June 2018, 10:34 PM   #79
Last progress. I´ll give datas for control to X.
JP
Old 27th June 2018, 10:45 PM   #80
Got Foam?
xrk971's Avatar
Looks good! So use a spring clip to clamp voltage regulator to heatsink vs screw hole. I need to get some clips.
For system with single DC-DC we will be limited to about 150mA bias current per channel as overall current limit is 310mA.
Simple High Performance DC Coupled Class A HPA with sub PPM THDHide this!Advertise here!
Ultra-high performance, yet rather simple - hybrid and more! vzaichenko Solid State 998 13th June 2018 12:12 PM
High Performance Class A Current Feeback Headphone Amplifier monty78pig Headphone Systems 14 12th November 2015 02:01 PM
Simple High-Performance DAC psk Digital Line Level 17 8th September 2014 05:41 AM
simple, high performance amp using DRV134? Fast Eddie D Headphone Systems 6 6th May 2014 06:17 AM
Huginn, High performance, Class A, Lateral FET headphone amplifier Neutrality Headphone Systems 11 7th November 2013 08:29 PM
Copyright ©1999-2019 diyAudio
