Group Buys Members group buys
Simple High Performance DC Coupled Class A HPA with sub PPM THD
Old 5th August 2019, 02:13 AM   #441
PiotrL is offline PiotrL  Ireland
I ended up having 2x2 pairs matched at about 27mA+-0.2mA. Got everything build, and see a DC offset of 25mV on left channel, which is OK-ish, but the right channel has an offset of -0.48V. Negative MOSFET is draining more current than the positive one. Voltage across R138 is 340mA and 300mA across R137, both are 2R7.
I'm not sure why that is the case. I have measured all resistors before soldering (obviously JFETs as well), inspected every joint many times, but the offset is there.
R126 is definitely OK, so the suspect is R128, but I have measured it before soldering, so why would it cause problems? R128 is actually through hole, so I don't want to take it out just yet. I have made an experiment of putting another resistor across R128 and it actual "worked". I mean that it eliminated the offset. I had to put some 400ohm across R128 which indicates that its 330ohm. It's really hard to believe. What other possibilities shall I check?
Piotr.
Old 5th August 2019, 03:27 AM   #442
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Hi PiotrL,
Please check with DVM probe all the voltages at each node of all actives and write by hand into the schematic. Then take photo or scan and post here. That’s the only way we can debug - it’s like a blood test and X-ray in an ER her they want to find what’s wrong with a person’s health. The major nodes are every leg of an active, the output node, and bias current in all legs.
My guess is you have a part that is incorrect or a cold solder joint. Take an iron and touch ea h joint to remelt it.
Parts variation can’t mKe 480mV offset. So it has to be a bad or incorrect part. Do you have correct sex BJT in place? Are all MOSFETs P-channel?
For convenience, here is schematic:
https://www.diyaudio.com/forums/atta..._001_page1-pdf
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 5th August 2019, 03:08 PM   #443
Thanks Xrk. All parts are sourced directly from links in the excel ss (Mouser). I did not measure BC857s, however having two spare left, they look ok on DCA75.
So I though that melting each joint will be easy first step. It was easy, but made things worst, output DC offset is now -0.75V.
Piotr.
Old 5th August 2019, 04:19 PM   #444
Got Foam?
xrk971's Avatar
Check for a bad JFET at V124. That’s an 11v drop and way too much for normal.
Old 5th August 2019, 10:38 PM   #445
OK, so I pulled out V124, but it measured fine on DCA75 and identical on Idss. This is actually impressive considering what it went through. I have done the same to V131 just in case because I did not measure it before and because it also differed from left channel equivalent . It was also OK. Next I checked all resistors around them, again OK. At this point I started to think that the circuit actually works fine, and it does what it supposed to do. It's just that there is something else on the board that pulls Vs of V124 down to 0.78V from about 1.5V like it is the case on the other channel.
I put back V124 and V131 on the board powered it up and observed same DC offset of -0.75V. Good: same predicateble behavior. So I stopped looking for faulty components and started looking for "additional/unwanted ones". I started scrubbing the board from flux dirt and started to remove excess of solder specifically around places where there are ground plane vias very close to component pads, and bingo! DC offset on the right channel in now -65mV, still high but R128 is actually not very well matched to R126 - this will get addressed later.
I have measured all voltages again FYI and indicated those which were wrong but now are matching left channel quite well. I'm sourcing this amp now from Arcam Irdac and listening to it on MSR7s. It eats my ifi iDSD nano for breakfast. Really impressive. All that bloody SMD work was a price worth paying for what I'm hearing now
Thanks again for help. I'll be back when I'll sort all remaining bits and pieces out and have a finished product in a decent case.
Piotr.
Old 5th August 2019, 11:16 PM   #446
Got Foam?
xrk971's Avatar
Nice work PiotrL! Glad you got it sorted out - and that is sounds great. It’s a neat amp, if you go through the trouble of building the DC-DC PSU with cap multiplier and regulator, it will sound even better.
Old 5th August 2019, 11:57 PM   #447
Yes, on that note... That little thing that you see on the right which is powering your amp is a BJT based cap multiplier fed from LM317/337 regulator implemented in low noise application: Simple Voltage Regulators Part 1: Noise - [English] and https://electrooptical.net/static/ol...NoisePeaks.pdf. I like BJT cap multipliers as they have much less voltage drop across them. That combo looks very good on my scope, so I think I'm grand in terms of PS for now. I'll definitely populate your DC-DC converter board some day, but for now I'll stay with that supply that I have laying around. I hope that's OK . I actually have two of them, build for some other HP Amp with independent channels, but that design had quite unacceptable MOSFET bias drift so it's gathering dust now while your's is playing out loud. Bias on your amp is really nailed, it doesn't move more than +/- 2mV/2.7ohm. Good stuff!
Piotr.
Simple High Performance DC Coupled Class A HPA with sub PPM THDHide this!Advertise here!
Ultra-high performance, yet rather simple - hybrid and more! vzaichenko Solid State 998 13th June 2018 12:12 PM
High Performance Class A Current Feeback Headphone Amplifier monty78pig Headphone Systems 14 12th November 2015 02:01 PM
Simple High-Performance DAC psk Digital Line Level 17 8th September 2014 05:41 AM
simple, high performance amp using DRV134? Fast Eddie D Headphone Systems 6 6th May 2014 06:17 AM
Huginn, High performance, Class A, Lateral FET headphone amplifier Neutrality Headphone Systems 11 7th November 2013 08:29 PM
Copyright ©1999-2019 diyAudio
