Group Buys Members group buys
Simple High Performance DC Coupled Class A HPA with sub PPM THD
Old 16th April 2019, 03:10 PM   #431
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Avtech,
That woven fiberglass/copper braid looks like great stuff but pricey at $32/meter. I guess you don't need much of it for a small preamp or HPA box. Thanks for the link.
I wonder if solder wick braid could be used for smaller cables. Sometimes, stripping off braid from used RG58 coax or household cable coax leftover bits can work too.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th April 2019, 04:32 AM   #432
yourownbuzz is offline yourownbuzz  Australia
Originally Posted by avtech23 View Post
Thanks X. I'll have a play around again when I get a chance. Too many projects to dwell too long! (Got all the bits for a Korg B1 that won't assemble itself!).
In the meantime, I'm pretty happy with the finish on this build.
this looks great, the sleeves are a nice touch - looks like you took a page out of the PC building book :P
Old 21st April 2019, 12:23 AM   #433
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Thanks buzz.
True, it does look like the PSU leads inside my PC! Must've been where the inspiration came from
I'll play around with it again at some point - I have an additional input to wire in when I decide what to put in - and might change the PVC out for the proper shielding sleeves (I've got an old stash of it somewhere).
I'm currently running an rPi with Volumio through an original hifiberry dac into some Audio-Technika ATH-M50x and it sounds pretty nice to me. Definitely worth the headache of soldering SMD!
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg. : VSQC Phunk Style, Retro 50W, Filmosound 601. : Apex AX-14, TGM-10, TDA7265, LM4780 (Last in line)...maybe
Old 13th June 2019, 08:28 PM   #434
Shawnstium is offline Shawnstium  United States
Has anyone used the 2sk209 in place of the BF862 with good results?
Old 13th June 2019, 09:28 PM   #435
Got Foam?
xrk971's Avatar
It should work fine. 2mA current in present design fits nicely in. 10mA max for 2sk209.
Simple High Performance DC Coupled Class A HPA with sub PPM THDHide this!Advertise here!
Ultra-high performance, yet rather simple - hybrid and more! vzaichenko Solid State 998 13th June 2018 11:12 AM
High Performance Class A Current Feeback Headphone Amplifier monty78pig Headphone Systems 14 12th November 2015 01:01 PM
Simple High-Performance DAC psk Digital Line Level 17 8th September 2014 04:41 AM
simple, high performance amp using DRV134? Fast Eddie D Headphone Systems 6 6th May 2014 05:17 AM
Huginn, High performance, Class A, Lateral FET headphone amplifier Neutrality Headphone Systems 11 7th November 2013 07:29 PM
Copyright ©1999-2019 diyAudio
