Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Group Buys Members group buys |
#371 |
Ok - rather inexplicably it works now. after checking for -16V I decided to swap out the BC857 as X suggested earlier. Put it on the transistor tester - it checked out. New one from the pack, also tested fine. Put in the new one and now voltages seem to be similar to the L channel (no sound test yet).
No idea why that did the trick - I did check the BJT for shorts before pulling it and it didn't seem like there were any. |
#372 |
Got Foam?
Excellent news!
How do you like the sound?
XRKaudio https://www.etsy.com/shop/XRKAudio |
#373 |
Got Foam?
I bet it was a cold solder joint on the BC857. Let us know what you think of the sound. For me, it’s one of the best headphone amps I have heard. Being DC coupled really gives it some amazing transparency and the depth of bass is very good.
#374 |
I actually killed my 7918 shortly after..I think the pins worked loose while testing and there was a spark.
Listening will have to wait until I get around to modifying the ldovr reg.. |
#375 |
Got the amp running with the ldovr regs (swapped the resistor as alexy said) and adjusted to within <0.1V on +ve and -ve rails.
My hardest to drive pair of headphones are Fostex T50rps. With a fraction of a turn of the volume knob its up to slightly higher than normal listening volume, and just for fun I turned it up higher (headphones on the desk of course). You weren't kidding when you said this thing has power! Will have to get it mounted up for a more extensive listening session & comparison. I'm kind of itching to build another to use as a speaker amp as you suggested |
#376 |
Got Foam?
YOB,
Glad to hear that the sound is good so far. Please post detailed descriptions of which resistor you modified on the LDOVR to program the correct voltage.
#377 | |
X - perhaps link this in the first post? |
#378 |
Been listening and comparing this amp to a few others - mainly with Fostex T50rp mk3.
This amp is great, drives them well and brings out low lingering bass on the T50s. Vs DCA - DCA doesn't give as much bass response Vs Aksa Lender HPA - to my ears sounds quite similar Vs O2 - O2 is positively anemic with the Fostex, and distorts as well. DCA much more worth it for the price O2s go for! |
#379 |
Got Foam?
YOB,
Thanks for the listening impressions. I have heard similar comments about the O2 vs even the little Pocket Class A. The DCA has 125mA, more than double the bias current. This amp, is in another class because it has an active CCS that sort of makes it a push pull even though it is SE Class A. The DC coupling makes a difference too. The PSU in this amp is truly state of the art - you can’t get a quieter power supply that is wall powered.
#380 |
to be honest I don't really know how the BF862 stage in this amp works ha...
Thread | Thread Starter | Forum | Replies | Last Post |
Ultra-high performance, yet rather simple - hybrid and more! | vzaichenko | Solid State | 998 | 13th June 2018 12:12 PM |
High Performance Class A Current Feeback Headphone Amplifier | monty78pig | Headphone Systems | 14 | 12th November 2015 02:01 PM |
Simple High-Performance DAC | psk | Digital Line Level | 17 | 8th September 2014 05:41 AM |
simple, high performance amp using DRV134? | Fast Eddie D | Headphone Systems | 6 | 6th May 2014 06:17 AM |
Huginn, High performance, Class A, Lateral FET headphone amplifier | Neutrality | Headphone Systems | 11 | 7th November 2013 08:29 PM |
New To Site? | Need Help? |
