I actually have one more of the full PCB set for the amp with DCDC and Cap Mx PSU, input select board, CLC filter, volume pot helper board, Xfeed board etc.
Good news is that I have plenty of the stand-alone amp boards but they have an easy to fix error (wire jumper and 2k2 resistor needed - see photo). These work great and are ideal for the DIY’er wanting to use his own PSU or to make a balanced (BTL) output amp.
The standalone boards are available here:
DC Coupled Class A Simple Headphone Amplifier | Etsy
You might also be interested in the SSR headphone DC protection circuit if you are going to make this amp.
Solid State Relay Headphone Amp Protection | Etsy
Just tested out the standalone boards with the Yarra PSU. It sounds fantastic! I forgot how good this headphone amp sounds. It is so direct and powerful. DC coupling makes a difference I think.
I might have to build another set of boards and make a balanced output headphone for myself.
2SK209BL is a drop in replacement.I got two times fake BF862 - giving up. How about the 2SK209 ? What is needed to be changed when using this fet ?
Use it !!!How about something like the 2SK3557? I've not tried them before but dirt cheap and plenty available at Mouser.
How did it work out? I'm dipping my toes into the whole smd thing and wondering if something like this will make my life easier...I just got myself an i-Extruder solder paste dispenser. Testing it now - amazing level of control.
YouTube
It works great but probably overkill for the hobbyist. I was working on a project with 700 parts so it made sense.
For most projects up to 200 parts a much less expensive manual dispenser like this works fine and is what I use most of the time now.
https://www.techni-tool.com/product...49Ucm0rDx0eQ-SHT2ZJTpZO4GVZMMYoRoCLrsQAvD_BwE
- Group Buys
- Simple High Performance DC Coupled Class A HPA with sub PPM THD
