Simple High Performance DC Coupled Class A HPA with sub PPM THD
Founder of XSA-Labs
Joined 2012
Harry3,
Can you mark up the schematic with what you are proposing?
685372d1528348988-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-simuation-schematic-v3-png
Do you mean make R13 2k2 and get rid of the 100R? The 2k2 acts with C4 as a filter, whereas the 100R is a gate stopper, which probably isn't needed as the 2k2 is already there. However, it matters where the node to the filter cap is located. I think you can leave R13 where it is but ok to get rid of the 100R at R4.
2. For the main MOSFET Drain resistors R117/118 and R137/138, please use high quality metal thin film as well. I only had thick film on hand, so once again, you may see significant improvement in distortion over my verification build if you choose this. I would start with the 2R7 values to get 115mA. If you really want 145mA then use 2R2 and that will be the maximum capability of the Traco Dc-DC (315mA for both channels).
X - found an inconsistency.
Thin or thick film for these ones (R117/118 and R137/138)? BOM lists thick for these (and that's what I ended up ordering), but you advise thin in the quoted post.
Founder of XSA-Labs
Joined 2012
On the feedback resistors (R16/107) and MOSFET source/drain power resistors (R115/116/117/118) especially, use either carbon film or metal thin film. If you use metal oxide thick film here, it tends to generate the unpleasant third order harmonic distortion. I have measured it and it is not insignificant. But only in places where there is a significant amount of AC-signal current induced heating. Some people argue that gate stoppers (R113/114) for MOSFETs should be carbon as well.
To be safe, use all metal thin film if you want. It will cost a bit more but will be safe and low distortion. The carbon thin film on the key feedback and ground shunt resistors will have a smoother ("less etchy metallic") sound.
685373d1528348988-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-timss-final-schematic-prod-png
