xrk971 Desktop Class A (DCA) Headphone Amp
Over in the Yarra thread we discuss the new setpoints for PCA/DCA daughterboard (same as DCA in principle) either the 2SK209GR or 2SK170BL(available from GB’s) or LSK170BL. Those 2SK209GR’s are Toshiba JFETs and still available.
The YARRA Preamplifier/HPA for Melbourne DB Group Buy
Use IRF610 or Fairchild FQP4N20 work very well too.
You will wait a long time since I have a lot of the original boards left. :)
Hi. Can i use MPF102 or 2sk30? Can you help with the resistor adjustment for MPF102 or 2sk30?
Thank you so much
Founder of XSA-Labs
Joined 2012
I don’t have models for those actives. You could search for the models yourself and put it into the LTSpice model. If you send me the schematic .ASC file with the models I can help you adjust it and optimize it. But I don’t have time to go find models and get it all to work for you. That’s your DIY part. Or you can use the parts I specified and no tweaking or adjustments necessary.
I built this up on veroboard with 2sk209gr as in the above schematic with a linear power supply. Sounds fantastic on my Grados! Very smooth and natural. Not quite as musical and nuanced as my much more expensive and complex 4p1l tube amp, but very good indeed. Thanks for sharing the design. Notice the gigantic 4.7uF Obbligato Copper input caps left over from a tube amp build.
Hi X. Thank you for the reply.
I want to build this amp as a standalone device. I decided to use 2sk170, based on this schematic and using resistor setting from this post
https://www.diyaudio.com/community/...or-melbourne-db-group-buy.334457/post-5898779
The question is:
1. Is the value correct for 32 ohm headphones?
2. What is the output impedance for this particular setup?
3. On the description it says that R102+R104 = 2K. That means 1K each, right?
BTW, am using cap multiplier on this thread.
Thank you
Founder of XSA-Labs
Joined 2012
The question is:
Thank you
The schematics says R103+R104=930ohms for 2SK170BL. That means the sim equals 930ohms not each. So 900ohms plus 30ohms, etc… in series.
It will work for 32ohm headphones but that is the limit for 125mA bias current. Change output cap to 2200uF for 32ohm load.
Output impedance requires a simulation but from memory I seem to recall it’s in the 3-5 ohms range.
Can i increase the bias to 150mA to lower the output impedance?
What is the effect 150mA bias to the harmonic distortion?
Am planning to use 2 transistor CCS, is that change the harmonic distortion?
Thank you
Yes, input cap is as big as you want. But 2.2uF film cap is about perfect. I sometimes use 10uF Silmic II but that’s just convenience and they are tiny. Output should be at least 2200uF electrolytic and bypass with a 2.2uF film cap.
Hi, pocket version have better gain than desktop version ? I compare two of them, the pocket version only need volume 2-3, than the desktop version need volume 7-8.
Joined 2023
A few more questions...
1) It looks like BF862 is an obsolete part. Is there a good replacement, and if so, what is it and does it require and resistor values to be changed from what's on the BOM?
2) for V111 and V112, the BOM shows IRF610 in Column 2 and IRF512 in Column 3. Does that mean either will work, with the resistor values on the BOM? It looks like IRF610 is currently available, while IRF512 is obsolete.
3) Also, I saw you mention that the next run of DCA boards might have solder mask over all the vias. If I wanted to wait for that next version of the board with the "tented vias", how long might I be waiting?
Pink,
Did you ever build the DCA? I'm considering it and have been stumped by the BOM . . . if you have a more or less complete/up to date BOM, send along.
Thanks!
Founder of XSA-Labs
Joined 2012
Here is a more detailed BOM for the DCA with capacitor dimensions etc so you can make informed choices for substitutions. Feel free to substitute the boutique Mundorf caps with something else. Many different lead spacings work as it is axial and you can bend the wires to fit. Use metal thin film resistors if possible, especially for parts in the audio signal path.
PartValueDevicePackageDescription
C10110 µ0CPOL-EUE3.5-8E3,5-8POLARIZEDElectrolytic 3.5mm pitch x 8mm dia
C101AC22/10C22.5B10CAPACITORFilm 22.5mm pitch x 10mm width
C101BC27/17C27.5B17CAPACITORFilm 27.5mm pitch x 17mm wide
C101C0 µ1MKC1860-0U1MKC1860-0U1Wima part number
C101D10 µ0MCAP250V10UMCAP250V10UFidelityMundorf Mcap part number
C10210 µ0CPOL-EUE3.5-8E3,5-8POLARIZEDElectrolytic 3.5mm pitch x 8mm dia
C102AC22/10C22.5B10CAPACITORFilm 22.5mm pitch x 10mm wide
C102BC27/17C27.5B17CAPACITORFilm 27.5mm pitch x 17mm wide
C102C0 µ1MKC1860-0U1MKC1860-0U1Wima part number
C102D10 µ0MCAP250V10UMCAP250V10UFidelityMundorf Mcap part number
C1111 µ0C5/5C5B5CAPACITORFilm 5mm pitch x 5mm wide
C111AC10/6C10B6CAPACITORFilm 10mm pitch x 6mm wide
C111BC15/8C15B8CAPACITORFilm 15mm pitch x 8mm wide
C1121 µ0C5/5C5B5CAPACITORFilm 5mm pitch x 5mm wide
C112AC10/6C10B6CAPACITORFilm 10mm pitch x 6mm wide
C112BC15/8C15B8CAPACITORFilm 15mm pitch x 8mm wide
C1132200uFCPOL-EUE7.5-18E7,5-18POLARIZEDElectrolytic 7.5mm pitch x 18mm dia
C113ACPOL-EUE5-10.5E5-10,5POLARIZEDCAPACITOR,Electrolytic 5mm pitch up to 18mm dia
C1142200uFCPOL-EUE7.5-18E7,5-18POLARIZEDElectrolytic 7.5mm pitch x 18mm dia
C114ACPOL-EUE5-10.5E5-10,5POLARIZEDCAPACITOR,Electrolytic 5mm pitch up to 18mm dia
C131220 µCPOL-EUE5-13E5-13POLARIZEDElectrolytic 5mm pitch up to 13mm dia
C1331 µ0C5/5C5B5CAPACITORFil 5mm pitch x 5mm width
C1342200 µCPOL-EUE5-13E5-13POLARIZEDElectrolytic 5mm pitch up to 13mm dia
C1352200 µCPOL-EUE5-13E5-13POLARIZEDElectrolytic 5mm pitch up to 13mm dia
C1412200 µCPOL-EUE5-13E5-13POLARIZEDElectrolytic 5mm pitch up to 13mm dia
C1422200 µCPOL-EUE5-13E5-13POLARIZEDElectrolytic 5mm pitch up to 13mm dia
C1431 µ0C5/5C5B5CAPACITORFilm 5mm pitch x 5mm wide
C1441 µ0C5/5C5B5CAPACITORFilm 5mm pitch x 5mm wide
R101RK09L12BRK09L12B
R102100kCMF-55CMF-55Dale 1/2W metal thin film 1%
R103100kCMF-55CMF-55Dale 1/2W metal thin film 1%
R10422k0CMF-55CMF-55Dale 1/2W metal thin film 1%
R10522k0CMF-55CMF-55Dale 1/2W metal thin film 1%
R1061k1CMF-55CMF-55Dale 1/2W metal thin film 1%
R10768R0CMF-55CMF-55Dale 1/2W metal thin film 1%
R108250RCMF-55CMF-55Dale 1/2W metal thin film 1%
R1091k1CMF-55CMF-55Dale 1/2W metal thin film 1%
R11168R0CMF-55CMF-55Dale 1/2W metal thin film 1%
R112250RCMF-55CMF-55Dale 1/2W metal thin film 1%
R11347R0CMF-55CMF-55Dale 1/2W metal thin film 1%
R11447R0CMF-55CMF-55Dale 1/2W metal thin film 1%
R115270RCMF60CMF60Dale 1W metal thin film 1%
R116270RCMF60CMF60Dale 1W metal thin film 1%
R117270RCMF60CMF60Dale 1W metal thin film 1%
R118270RCMF60CMF60Dale 1W metal thin film 1%
R119270RCMF60CMF60Dale 1W metal thin film 1%
R121270RCMF60CMF60Dale 1W metal thin film 1%
R122270RCMF60CMF60Dale 1W metal thin film 1%
R123270RCMF60CMF60Dale 1W metal thin film 1%
R124270RCMF-55CMF-55Dale 1/2W metal thin film 1%
R125270RCMF-55CMF-55Dale 1/2W metal thin film 1%
R13110k0R-EU_0207/100207/10RESISTOR,2mm dia x 7mm long body, 10mm pitch axial
R132220RR-EU_0207/100207/10RESISTOR,2mm dia x 7mm long body, 10mm pitch axial
R1331R5R-EU_0207/100207/10RESISTOR,2mm dia x 7mm long body, 10mm pitch axial
R1340R47R-EU_0309/120309/12RESISTOR,3mm dia x 9mm long body, 12mm pitch axial
R1350R47R-EU_0309/120309/12RESISTOR,3mm dia x 9mm long body, 12mm pitch axial
V101BF862SST201SOT23TEMICSOT23 SMT package
V102BF862SST201SOT23TEMICSOT23 SMT package
V103JFET2SK170TO92-DGSFieldTO92 package
V104JFET2SK170TO92-DGSFieldTO92 package
V111IRF610IRF512TO220BVN-CHANNELTO220 package
V112IRF610IRF512TO220BVN-CHANNELTO220 package
V1311N40041N4004DO41-10DIODEDO41 package axial 1A diode
V132IRF610IRF512TO220BVN-CHANNELTO220 package
X10122-27-2021-0222-27-2021-026410-02CONNECTORMolex KK 2-pin 2.5mm pitch connector
X10222-27-2021-0222-27-2021-026410-02CONNECTORMolex KK 2-pin 2.5mm pitch connector
X11122-27-2021-0222-27-2021-026410-02CONNECTORMolex KK 2-pin 2.5mm pitch connector
X11222-27-2021-0222-27-2021-026410-02CONNECTORMolex KK 2-pin 2.5mm pitch connector
X13122-27-2021-0222-27-2021-026410-02CONNECTORMolex KK 2-pin 2.5mm pitch connector
X132AK500/2AK500/2CONNECTORunknown2-pin 10mm pitch screw terminal
X1011SK104SK104SK104HEATSINKFischer Heatsink SK104
X1012SK104SK104SK104HEATSINKFischer Heatsink SK104
X1031SK104SK104SK104HEATSINKFischer Heatsink SK104
Pink,
Thanks!
I did not, sorry. Hopefully xrk can clear up any other questions you have. As you may have seen I too was confused by some of the nomenclature in the BOM, but I believe xrk answered those questions here in the thread.
