Group Buys Members group buys
PeeCeeBee V4H GB
PeeCeeBee V4H GB
Old 8th May 2019, 09:32 AM   #801
bambadoo is offline bambadoo  Norway
Hmm - have a couple of smps +-45Vdc laying around. Will try them. Still waiting for parts so I can start soldering.
Not sure if it has been said before. What is the PSRR of the V4H modules?
Sincerely
Old 8th May 2019, 02:32 PM   #802
shaan is offline shaan  India
shaan's Avatar
PSRR hasn't been measured for v4/v4h. However as I can't hear any hum with only 10000uF in the rails I guess PSRR is high enough for a dark background.
V4 GB! | V4H GB!!(ONLINE) | PSU GB!!!
Old 19th May 2019, 06:07 PM   #803
delange is offline delange  Belgium
Hi Shaan,
Happy to report that I received my PCB's last week.
A question in regards to the heatsink requirements: do you think an SK 85 75 SA heatsink is sufficient for one channel?
This heatsink has a thermal resistance of 0,45 K/W.
Old 19th May 2019, 07:51 PM   #804
After a year waiting. About to start.
Old 19th May 2019, 09:02 PM   #805
Cresnet is offline Cresnet  Jordan
MicroAudio
Cresnet's Avatar
PeeCeeBee V4H GB
Nice PCBs!
http://www.diysmps.com
Old 20th May 2019, 06:52 AM   #806
Yes, have complete parts for 4 channels. But only need 2
Would it be any benefits if making it complete balanced or should I just make 2 amps?
Thinking.....
Old 24th May 2019, 06:04 AM   #807
Quick question:
After the setup procedure has been done. When closing J1 and J2 , what is the purpose of Q5 and Q6?
Do they affect the SQ at all?
And: Since I have some 2sc2240bl and 2sa970bl laying (good matched) - would these yield any benefit instead of bc546/bc556 in the different locations?
Of course I have to change the pin layout of these
For VAS transistors. Can I use ksc2690ays/ksa1220ays? Have some of those also...
Sincerely
M
Old 24th May 2019, 07:40 AM   #808
shaan's Avatar
Quick question:
Closing the jumpers shorts base and emitter of these bjts, turning them fully off. There is no impact on SQ.
Yes these can be used. But might look odd on board.
No these can't be used safely. Each vas transistor will face nearly double the rail voltage i.e. approx 112V with 56V supplies at clipping, which is too close to their 120V rating.
Old 24th May 2019, 08:05 AM   #809
Thanks for quick response. Agree with you comments.
I am aiming for +-45V on 2 of the boards. That was were I was thinking of the ksc2690/ksa1220. On the other 2 board (Potential higher rail voltages) IŽll search my drawers to find something more useful
Old 24th May 2019, 08:33 AM   #810
shaan's Avatar
I think 45V won't be much problem for them. Total collector to emitter voltage at clipping will be 30V less than their rating. So for the two boards I think they will work fine.
PeeCeeBee V4H GBHide this!Advertise here!
PeeCeeBee V4 GB! shaan Group Buys 1023 28th September 2019 05:28 AM
PeeCeeBee shaan Solid State 2806 4th September 2019 12:18 PM
FS :PeeCeeBee V4 meanman1964 Swap Meet 0 1st December 2017 03:54 AM
Retro PeeCeeBee inspired by Juma. gannaji Solid State 20 21st November 2017 01:41 AM
FS: PeeCeeBee PauloPT Swap Meet 10 2nd September 2016 03:48 PM
Copyright ©1999-2019 diyAudio
