PeeCeeBee V4H GB
Work in progress..
Hello,
please HELP :confused:
When setting VAS biasing, I was carelessly manipulating the multimeter probe and a short time I connected the legs R25 and R39. :headbash:
It sparkled a bit and the R4 resistor burned out before I turned off the power on. Shown in the picture below.
What was destroyed? Transistor? Who? :scratch:
I'm not an expert to find a mistake. I can only measure components if I know which ones.
I hope this is a small problem and I can repair it.
Thank you for the advice. :worship:
Hello,
Hi Robodo.
Check all the resistors. Replace the burnt ones.
Check all bipolars for base-emitter and base-collector voltage with multimeter in diode test mode. For Q1,3,5,7,9 black probe goes to base, for Q2,4,6,8,10 black probe goes to base. Pin 2 is base for small bipolars and pin 1 is base for Q9/Q10. If any junction shows open or short, replace that transistor. Remove jumpers before probing.
Hi Robodo.
Hi shaan,
Thank you for your help. I measured all the resistors and replaced only the burned R4, the others were fine. Then I measured the transistors and I detected faulty Q2
First I also desoldered the Q4, Q8 and Q10 because I thought they were also defective,...
shaan said:
...for Q2,4,6,8,10 black probe goes to base
...before I found out that for NPN transistors it is necessary to apply a red probe goes to base and then these transistors were already good.
So I soldered them back. I'm glad I have more of these transistors, because I destroyed the desoldered ones.
After attaching the finished board to the heatsink and connecting the power supply. Everything seems to be fine.
Tomorrow I will make setup VAS, Offset and more, I'm finishing today.
I don't like two differences. It just seems to me that the LED D6 versus D5 is a little dimmer. And resistance between the output terminal and heatsink body is 4,7 MOhm.
This does not happen with the second PCB module. I already have it installed and all setup fine.
Any advice? Thank you.
Robert
Replace the led that's dim.
If it's showing 4.7Mohm without heatsink connected to psu ground then somewhere there is a slight leakage between mosfet backs and heatsinks. Replace the insulators.
Hi shaan,
the resistance between ground and output is ok. I measured it with the power supply connected :headbash:
Today I tried to set the VAS, but the mV value didn't want to change, still 0mV, even though I was rotating VR1 and VR2. As the VR2 rotates, LED D6 dims to completely dark. If I turned the trimmer back to the maximum resistance, then is the light back on D6 :confused:
I'm finishing today, I won't continue until after the weekend. I should give time to my family :eek::)
Robert
