Group Buys Members group buys
PeeCeeBee V4H GB
PeeCeeBee V4H GB
Old 20th February 2019, 07:35 AM   #741
Harry3 is offline Harry3  Australia
Default cleaning boards
gaborbela use a stiff tooth brush with the alcohol and "scrub" the flux.
Then wash off the residue with clean alcohol and dry with a clean cloth.
Try not to get the alcohol under the electrolytics or into the trim pots.
You might need to do this a few times.
I usually solder the resistors and quick connects first and then thoroughly clean my boards. After that I solder the caps and transistors.
Hope that helps.
Old 22nd February 2019, 04:42 AM   #742
bvtrinh is offline bvtrinh  United States
Finished the boards and cleaned up the power supply. Itís dead quiet. So much so that I wouldnít even know the amp was on. While playing music, it almost seems like something is missing but in reality it is not. I can hear the details and separation of the voices and instruments. The bass is tight and makes the Tang Bands W8s have a fuller sound. I will report more of my impressions once I listen to it some more.
The amp itself uses two SMPS600 from Cresnet (I highly recommend) along with an addition cap bank per SMPS. For the input, Iím using XLRs converted to single ended by Cinemags 15/15b transformers.
Old 22nd February 2019, 05:35 AM   #743
Very nice build and good shielding.
How big are the "extra" caps after the SMPS?
Old 22nd February 2019, 05:35 AM   #744
shaan is offline shaan  India
shaan's Avatar
Hi Bao.
Congrats. Have fun with the v4h.
One question, I don't see a connection to SGND. Is it connected underboard?
V4 GB! | V4H GB!! | PSU GB!!!
Old 22nd February 2019, 07:42 AM   #745
bhrt is offline bhrt  India
It took a long time to get the silver mica for the rev1. Mod. But they are here, finally the board's are complete now.
Old 22nd February 2019, 08:45 AM   #746
J.M.K is offline J.M.K  France
Hi !
Where did you get this nice enclosure from, can't read the brand
Thanks, very nice work
JM
Old 22nd February 2019, 09:55 AM   #747
Harry, the extra capacitors are Mundorf Mlytic AG 4700uf.
Shaan, yes all the wiring is underneath the boards as well as the subchassis. Thank you for the wonderful amp and support!
JM, the enclosure is based on a Pioneer home theatre receiver. I made the subchassis to mount the heat sinks as well as the front and rear fascia. The subchassis also hides the wires. The front faceplate was made to match the Integra receiver. It has lettering I made; however, it says the old amplifier modules I had in there.
Bao
Old 22nd February 2019, 10:46 AM   #748
Vunce is offline Vunce  United States
PeeCeeBee V4H GB
Hi Bao,
Fantastic build!
Now, enjoy your new V4H
Old 22nd February 2019, 02:21 PM   #749
Thank you Vunce! How are you enjoying yours?
Old 23rd February 2019, 04:07 PM   #750
Cresnet is offline Cresnet  Jordan
MicroAudio
Cresnet's Avatar
PeeCeeBee V4H GB
@bvtrinh
Nice build indeed, I like the enclosure too!
http://www.diysmps.com
PeeCeeBee V4H GBHide this!Advertise here!
PeeCeeBee shaan Solid State 2805 6th March 2019 12:43 PM
PeeCeeBee V4 GB! shaan Group Buys 954 4th March 2019 06:00 PM
FS :PeeCeeBee V4 meanman1964 Swap Meet 0 1st December 2017 03:54 AM
Retro PeeCeeBee inspired by Juma. gannaji Solid State 20 21st November 2017 01:41 AM
FS: PeeCeeBee PauloPT Swap Meet 10 2nd September 2016 03:48 PM
Copyright ©1999-2019 diyAudio
