In case anybody here have troubles or doesn`t have time to build their own peeceebee amp, I have mine for sell:
FS: PeeCeeBee V4H amplifier in compact chassis
It is Rev 1 version, stable and producing superb sound.
Q1 / Q2 Matching
I'm having a hard time matching Q1 - Q2
Most BC546B I found have hfe around 415
and most BC556B hfe around 290 -> 330
I have 2 best couples BC546=276 / BC556=281 wich is good
and BC546=402 / BC556=341 .... not so good
And I need some more for another amplifier.
My sources for bjt are Mouser and Farnell.
Any idea for a source of BC546B with a hfe lower than 400 ?
Thanks a lot
JM
Thanks a lot
JM
I did some research on the net, and it looks like there are not so many brands beside Fairchild available.
I just ordered a bunch of BC546b & BC556b from Conrad
Diotec Transistor (BJT) - Discret BC546B TO-92 1 NPN | Conrad.fr
and hope something good will come !
Diotec is a german company, who knows who is manufacturing their transistors.
I'll tell you more when they will be here
JM
JM
Thanks a lot
JM
BJT & Bipolar Transistors | RS Components
I get the Onsemi "BTA" suffix ones from the RS India site. Also am going to get an bunch of them from Taiwansemi next month. The NPNs have an average hFE of 275 and the PNPs 345 (all the PNPs seem to have a higher gain). Hope this helps your case.
One of my LEDs goes out when I plug in my speaker. I'm trying to test one channel only. Using SMPS, no other modules at all.
Things I've tried:
Completed VAS biasing
Completed offset trimming
Completed mosfet biasing
Heatsink is connected to chassis ground
No continuity between output terminal and heatsink
jumpers connected
One chassis ground point, speaker return, sgnd, pgnd
Things I've tried:
jumpers connected
Is your return cable from the -ve binding post on amp chassis connected to the chassis ground? Shouldn't it connect to the mid-point of the power supply smoothing capacitors?One chassis ground point, speaker return, sgnd, pgnd
Really need better pictures (multiple angles at high resolution) and tell us exactly what SMPS you are using.
Have you verified you have correct voltages from +/-Vdc with and without the amp board?
Edit: Could be wrong, but looks like a single voltage SMPS by your pic? You need dual voltage smps.
I haven't seen lots of SMPS spec, but I've never seen any which has symmetrical bipolar output. I've usually seen people using two single-ended SMPS "one below the other" to create a symmetrical supply. Can you point me to symmetrical output SMPS models?Edit: Could be wrong, but looks like a single voltage SMPS by your pic? You need dual voltage smps.
Cresnet / Microaudio
Go and see Sami there ............
Audio SMPS units for sale
His smps modules will fit perfectly ........
JMK
JMK
Ah, I've heard about Cresnet.
JMK
One more vote for Cresnet SMPS!
Yes I have used SMPS with double output for positive and negative voltage out, with earth as the center. For my V4H I use two 800VA with ±55V (500VA continuous load at 25° C).
And there are many with double voltage output (±) in the market, many suppliers set up to the voltage you want within given parameters, so there is probably always something to find that fits.
Ref to my previous post #1457 with a picture of the amplifier.
Helge
Helge
Supplier in France:
- CONNEX SMPS2000RxE Switched Mode Power Supply Module 2000W +/-55V - Audiophonics
Ref to DiYAudio page:
- Audio SMPS units for sale
GB UPDATE:
Torvbakkane - 6 PCBs - SHIPPED
Faizal Mansar Alam - 2 MODULES - SHIPPED
J.M.K - 4 PCBs - SHIPPED
prairieboy - 2 PCBs - SHIPPED
nrabbit - 2 PCBs + MOSFETS - SHIPPED
deps - 2 PCBs - SHIPPED
Greg1017 - 2 PCBs + MOSFETS - SHIPPED
CitizenKane - 4 PCBs - SHIPPED
surajspai - 2 PCBs - SHIPPED
Rick G - 4 PCBs - SHIPPED
blek stena - 2 PCBs - SHIPPED
routhun - 2 PCBs - SHIPPED
apnneto - 2 PCBs - SHIPPED
RobSoet - 4 PCBs + MOSFETS - SHIPPED
Pistollero - 2 PCBs + MOSFETS - DELAYED DUE TO TEMPORARY SUSPENSION OF SERVICE.
The suspended one will be shipped as soon as shipping service resumes to Portugal. I exhausted my last set of the SMD diodes and the subsequent batch from RS took about three weeks to come due to some complication. As a result the last few shippings got delayed.
Thanks to everyone for your patience.
still trying to matchv Q1 / Q2
I'm still into it.
The best Hfe match I got are some BC556B around 348 and
almost all BC546B around 414.
Is it going to actually make any audible issue ?
Anybody knowing a reliable source for something better ?
JM
Thanks a lot
JM
I'm still into it.
JM
- Group Buys
- PeeCeeBee V4H GB
