Group Buys Members group buys
PeeCeeBee V4H GB
PeeCeeBee V4H GB
Old 2nd January 2019, 07:19 AM   #641
Harry3 is offline Harry3  Australia
That sounds like an improvement - thanks for all the hard work Shaan.
For the P channel Mosfets, are the gate resistors smaller than the N channel resistors?
Looking forward to the new schematic.
Old 2nd January 2019, 08:06 AM   #642
jacques antoine is offline jacques antoine  France
PeeCeeBee V4H GB
Happy New Year Shaan!
I still have 2 unmounted original V4H PCBs. Will it be possible to apply the new mods to those?
Jacques
Old 2nd January 2019, 03:06 PM   #643
shaan is offline shaan  India
shaan's Avatar
Gate resistors same for both N and P channel MOSFETs.
Jacques
Yes it will be possible.
V4 GB! | V4H GB!! | PSU GB!!!
Old 2nd January 2019, 04:09 PM   #644
shaan's Avatar
Default V4H Rev1 Mod Tutorial
Hello PeeCeeBee V4H owners.
Here is how you can upgrade your boards with the Revision 1 Mod (shown for one channel).
Step 1:
Get 6 nos. 47pF/500V capacitors, ceramic or silver mica (12 nos. for two channels). These can be the same caps used for C5 and C6. Also get four 100ohm / 0.25W resistor for each channel.
Step 2:
Bend their legs in the way shown in the picture below. Two of them bent at 90 deg and the rest bent at 45 deg, about 3mm far from their body.
Step 3:
Cut the legs as shown. Keep the 90 deg legs a little shorter and 45 deg legs a little longer.
Step 4:
Take the two 90 deg bent capacitors and solder them on the bottom of the board as shown in the two pictures below. Solder one leg of each cap to a solder joint of the 1uF capacitor, and solder the other leg to the PGND solder joint. Make sure the capacitors lie flat so that when the board is mounted they don't touch the heatsink. Also take care so that thier legs don't touch any other solder joints.
Step 5:
Take the four 45 deg bent capacitors and solder each of them between pin 1 and 3 (gate and drain) of each MOSFET, as shown in the picture below.
Almost done.
Step 6:
Replace R27 through R30 with 100ohm resistors.
Step 7:
Mount the board on heatsink and set-up bias and offset following the guide shared in Post#1. If those were already set beforehand then no need to do it again, DC settings won't change after the mod.
Done.
____________________________
The Rev1 V4H layout looks like this. C23 through C28 added. Gate resistors will be changed in schematic, but places remain the same.
Thanks and
Old 2nd January 2019, 04:37 PM   #645
bhrt is offline bhrt  India
Hi Shaan
Thanks or the tutorial.
what are these two caps for?
Old 2nd January 2019, 04:45 PM   #646
gaborbela is offline gaborbela  Canada
I chose EXICON mosfets (all do I had the Hitachi also) for my application if I understand well that would work well without oscillation.
Shaan please let me know, my PC boards NOT mounted on a heatsink yet.
Thank you!
In case I must do these mods.
I have to order the recommended parts from Partsconnexion from where I ordered the rest of the parts
I do hate desoldering- I use silver solder, for the second time does not want to melt and it can destroy the PC boards
Old 2nd January 2019, 04:45 PM   #647
shaan's Avatar
Originally Posted by bhrt View Post
Hi Shaan
Attachment 726199
VAS ground caps, the same as the ones soldered under the board. I took this picture while experimenting.
Old 2nd January 2019, 04:50 PM   #648
shaan's Avatar
Thank you!
You don't need to desolder anything. If you use the mod then place 150ohm in parallel with 330ohm gate resistors and 220ohm with the 220ohm gate resistors.
Old 2nd January 2019, 04:56 PM   #649
ckwong99 is offline ckwong99  Hong Kong
In step 4 how can i solder two caps on the top side of the board ?
Old 2nd January 2019, 05:13 PM   #650
bambadoo is online now bambadoo  Norway
Is it possible to update this information i post#1?
Always great to have gathered all good information in first post.
PeeCeeBee V4H GBHide this!Advertise here!
PeeCeeBee V4 GB! shaan Group Buys 983 14th May 2019 06:40 AM
PeeCeeBee shaan Solid State 2805 6th March 2019 12:43 PM
FS :PeeCeeBee V4 meanman1964 Swap Meet 0 1st December 2017 03:54 AM
Retro PeeCeeBee inspired by Juma. gannaji Solid State 20 21st November 2017 01:41 AM
FS: PeeCeeBee PauloPT Swap Meet 10 2nd September 2016 03:48 PM
Copyright ©1999-2019 diyAudio
